10 Second Club Now you are haulin! 10s are sweet
Finally got a 10
Old Aug 11, 2005 | 06:55 PM
SlowTA98's Avatar
Default Finally got a 10
I went 10.96 at 124 at local track. Also the front tires decided to come off the ground too,only a inch or two. All the hard work a nd money spnt the car finally did somtheng good for me.
Old Aug 11, 2005 | 08:16 PM
Sukkoi19's Avatar
Saw it happen, nice runs.
Old Aug 11, 2005 | 08:52 PM
CrawlinWS6's Avatar
Import Patrol
What is your set-up that you have going on your car.
Old Aug 11, 2005 | 09:05 PM
scalemaster's Avatar
Hey congrats on the 10's
Old Aug 13, 2005 | 05:07 PM
SlowTA98's Avatar
My set-up is heads,cam,ls6 intake long-tubes, x-pipe flowmaster mufflers, th-400, big converter, 150- shot center line wheels with et streets. Suspension, I have bmr k-member a arms, adj tq arm, bmr lower control arms and relocation brackets
Old Aug 13, 2005 | 07:40 PM
RED98WS6's Avatar
I'd say you should be running mid 10's with that setup. Maybe 10.6x?
Are you having some trouble hooking up?
Old Aug 14, 2005 | 08:53 PM
SlowTA98's Avatar
not really having any traction problems. I think there is alot to be had in the set up still. The pinion angle is way out of wack and dont know alot about setting that stuff up. Im sure there are a few secrets that people know about that but I will have to figure that stuff out with some test and tune. The cuts high 1.6 60 fts lealing with the converter stalled. Also I think the car could use a different converter, I got a tci super street fighter 3500-4000. I am not sure that it is not locking up.
