10 Second Club Now you are haulin! 10s are sweet
10's outa the question?
Old Feb 16, 2006 | 01:56 AM
oldschoolmuscle's Avatar
Default 10 second pass am i outa my mind?
hey
99camaro
346, LT, open headers, with ls1 intake, ported tb. with a sd tune.
dart 225 heads
tsp 233/239
9in not sure what gear i want to run
nx wet shot 150
th400 on the trans brake.
seein what the experts think, i have some stuff to sort out but i am hoping for 10s by the end of the year.
you think its possible.
Old Feb 16, 2006 | 10:36 AM
B-MAN's Avatar
What's the stall on the converter? very important.
411 gears with a tall tire will help.
LS6 intake would be better
with a 150 shot you will want to retard your timimg about 7 degrees and run cooler plugs.
I would highly recomend a good tune (LS1 edit)etc... . You need to know where you are before you make a lot of decisions.
Possible if you do it the right way.
hope this helps.
Old Feb 16, 2006 | 10:44 AM
well my tranny guy told me he recomends a 10in lockup convertor stalling around 5k or so. i run tr6 plugs in the car, the car will be tuned for nitrous.
down the road i iwll be running a ported ls2 intake.
Old Feb 16, 2006 | 09:47 PM
70Stang's Avatar
Oh yeah...easy 10s.
I went 11.20 alot less and hoping to run in the 10s with that same cam, but stock heads...
Old Feb 18, 2006 | 01:03 PM
well thanks for the input
Old Feb 20, 2006 | 08:21 AM
what do you guys recomend as far as gears go? i still wanna be able to cruise down the road at 55-60mph, at a reasonable rpm.
Old Feb 20, 2006 | 12:02 PM
B-MAN's Avatar
4.11 gears are fine without a nitrous setup. If your going to race with nitrous when you do race. Go with 3.73 gears.
