10 Second Club Now you are haulin! 10s are sweet
Gauging interest in 10's
Old Feb 23, 2006 | 01:01 PM
jessedale98's Avatar
Default Gauging interest in 10's
LOl, well like the title says im interested. Ive ran a best of 11.6 @ 119mph with a 1.8 60 ft. (stock suspension) on nitto's. Now ive got Adj LCa, SFC's,pnhrd bar with 26inch tall slicks. and will be moving fromt the 125 shot, to 175. I will be removing about 100lbs of weight off my car. So tell me, with my mph and if i can get a 1.5 60ft. Is it worth trying?
Old Feb 24, 2006 | 12:35 PM
dam, why is it ls1tech.com people rarely get a response, but at z28.com they always get a response. dammit.
Old Feb 25, 2006 | 08:57 PM
B-MAN's Avatar
175 horsepower shot on stock internals isn't a good idea unless you're planning on rebuilding your motor soon. Secondly, you might want to consider a stronger rear end if you're going to run 10's. I have a strong feeling your stock rear end will not hold out, especially with 3.73 gears. A good tire to try are the 27" Hoosier quick time pros. They are the Hoosier equivalent of the Mickey Thompson ET streets. Only difference is - you can get them 27" and they still fit in your wheel well without having to trim the wheel well back. Another good idea would be to switch to 15" rims so that you can maximize the use of good tires. 15" rims and a 27" tire will allot for good grip and slingshot action. You should be able to hook a very respectable 60 foot time. Have you considered long tube headers, a bigger cam, head work? All of these are better options than increasing nitrous. The most reliable way to build a racecar is to build as much horsepower or as strong a motor as possible without the nitrous and then use nitrous for additional power after you've reached the engine's potential. This way you're not hitting a week motor with a heavy shot of nitrous...instead you're hitting a strong motor with a lighter shot of nitrous - therefore increasing the life expectancy of your motor. Good luck. I hope this helps. I'm not quite sure if this is the info you were looking for. If there is any way that I can help, please feel free to post back and I'd be happy to share my thoughts/experience with you.
Old Feb 25, 2006 | 10:45 PM
My rear end is well built and actually its stronger now then it was last week (410s)
I planned on taking timing out and adding a walbro255 pump. But, is 10seconds possible?
Old Feb 25, 2006 | 10:57 PM
B-MAN's Avatar
What tires are you running?
What's your race weight?
Are you running open exhaust?
What kind of power are you making?
All these questions make a difference.
Old Feb 25, 2006 | 11:28 PM
I plan on running either 26' or 28' mickeythompson et streets.
I have no cats and a cutout
Somewhere around 520rwhp
3725lbs
My 11.6 was on nittos and a 1.8 60ft, and a 125 shot. i have since then bought sfc,lca,adj panhard bar. and plan on upping the shot to 175
Old Feb 26, 2006 | 08:30 AM
B-MAN's Avatar
If you have 520 RWHP and weigh 3750 lbs with a 1.6sec 60' time. You should be in the 10's already. If not, somthing is going wrong whilr going down the track. Tht first time I went tens,I was a making 500 RWHP and weighed 3800lbs with a 1.62 60" time.
Try 27" Hoosier qicktime pros. It'sthe biggest DOT tire that will fit in the wheel well without cutting.
Good luck.
Old Feb 26, 2006 | 09:47 AM
Torkman15's Avatar
10 Second Moderator
Good luck.
The first time I dipped into the 10s I only had 440 RWHP 3400 lb Camaro with 28 12.50 ET Streets. Running 10s with my stick car is a little tougher than an auto on spray but the more tire the better. Keep in mind the 10 bolt will act like a fuseable link with that much power and a sticky track.
Good luck to ya, 10s are cool
Old Feb 26, 2006 | 02:46 PM
Thank you for the inforamtion, the 1/4 track opens up in a couple weeks.
