4L60 or 80's???
You can use a Window Switch to not spray through the shifts. It controls the nitrous with an On RPM and Off RPM. So you can set the start at about 3,000rpm and then set the off about 200rpm before the shift. You should really run one even if you spray through the shifts because if the tranny slips and the car bangs the limiter on the nitrous you can do some serious damage.
Definitely use a window switch. I would consider even a basic nitrous kit incomplete without one. Set it to shut off the nitrous and extra fuel (assuming wet kit) before your rev limiter but after your shifts. I prefer to spray through the shifts because shutting off the wet kit momentarily during a pass can result in lean spots and that is NOT good.
I don't spray very often, but I have a solidly built 4L60E in my '94 and did spray occasionally and it was always through the shifts. No problems.
I will spray my new setup once I am done dialing it in on motor. I will need to change the plugs to one heat range colder and gap 'em tighter, and then I will open the bottle.
New track times to come next week.
http://media.putfile.com/PAULASUPHIGH2
