10 Second Club Now you are haulin! 10s are sweet
Another can I make it!!!
Old Mar 26, 2006 | 10:03 PM
SPRAYED 01's Avatar
Default Another can I make it!!!
Just finished my mods for this winter and am getting ready to hit up Union Grove in Wisconsion April 9th. Just wonder what every one thinks of some time. Last year pulled and 11.5 at 124 with and 01 ws6 six speed. Mods were bfg drag radials, Adjustable torque arm,lid,mass air,headers not cats,pro 5.0,tnt 150 shot,fuel pump. I just added a tr224 cam with dual springs,titanium retainers, spec III+,moser 9inch with spool 35 spline axles,MT ET streets,275-40-17, dyno was with spray 548hp and 703 ftlbs. Stock weight pretty good driver, plan on spraying off the line at about5k shifting at 6300. Any ideas??
Old Mar 28, 2006 | 10:45 PM
SPRAYED 01's Avatar
Default Any one???
Some one has to have an idea or opinion on this. Right???
Old Mar 29, 2006 | 09:21 AM
BIRDONNOS's Avatar
should be right there at it
Old Mar 29, 2006 | 09:46 AM
ls1mongrel's Avatar
If you can get it to 60ft good then you may make it !
Old Mar 29, 2006 | 11:10 PM
SPRAYED 01's Avatar
im hoping if i can to a 1.5 60ft lanching at 5k with spray ill be good to go.
Old Mar 30, 2006 | 01:11 AM
gnx7's Avatar
Shift higher if the cam is still making power. I don't see why you can't shift a few hundred RPM higher as your limit. What does the dyno say?
Old Mar 30, 2006 | 12:16 PM
SPRAYED 01's Avatar
Its makin power untill about 6300.
