10 Second Club Now you are haulin! 10s are sweet
smallest drag radial?
Old Feb 21, 2007 | 09:51 AM
Getav8's Avatar
Default smallest drag radial?
Has anyone pulled off a 10.99 or better with a stock 16" rim with a drag radial? If so what was your weight, HP, suspension set up, what settings, and what brand tire? If you don't want your secrets out pm me.
Thanks,
Dave
Old Feb 21, 2007 | 03:49 PM
bluehawk2's Avatar
A buddy of mine just ran a 10.67 and Hattiesburg, MS. He was on 17'' TT2's with MT Street Radials . Stock suspension except a torque arm and poly bushings on the stock lca's. Battery relocated to the back along with his water cooler tank for the vortech sc. Don't know the weight, but it is a stock long block TA with the stock ten bolt. Don't know the hp.........it is a stock long block with a vortech SC spraying 125 nitrous. He runs his tires really low...........like 15 lbs.
Old Feb 22, 2007 | 10:02 AM
Getav8's Avatar
Who is he I'm in miss. too.
Old Feb 22, 2007 | 12:58 PM
bluehawk2's Avatar
He is from Tupelo. He was out there on Sunday in a red WS-6. He made a 11.20 pass-No nitrous and then he sprayed in 2nd gear and ran a 10.67. He made a third pass, but the track was not hooking very well. They didn't show a 1/4 time on the third pass, but he ran 6.90 in the 1/8th.
Old Feb 24, 2007 | 05:23 PM
Getav8's Avatar
Come on someone has to have made a break into the tens with a small drag radial.
Suspension guru's, anybody get a car to plant the hell out of a set of 16" 255 nitto's or mt?
Old Feb 24, 2007 | 06:19 PM
gnx7's Avatar
The M/T tires will work way better than a Nitto DR. That being said you will get about 3K miles out of the M/T and you can get 10-15K from the Nitto DR's.
Old Feb 24, 2007 | 06:23 PM
bluehawk2's Avatar
255/50/16's will hook better than DR's on 17's
Old Feb 24, 2007 | 09:11 PM
MARKSZ71's Avatar
i been 7.0s wihich is close to a high 10 on a mickey 255 60 16
Old Feb 24, 2007 | 09:25 PM
bluehawk2's Avatar
That is what I am hoping for this spring. Guess i will see if the 16's will hold a nitrous launch.
Old Feb 24, 2007 | 09:36 PM
my94blackz's Avatar
Ive ran 11.03 on the 17" M/T's. This was in a 500 RWHP lowered, full weight, stock head and intake, 6speed LT1 car.
Old Feb 25, 2007 | 10:49 AM
sleeperstyle's Avatar
stock wheels here, 255-50-16 mickey thompson drag radials. going to a 28" M&H drag radial soon on the stock 16" wheel, so i can attempt to make it across the traps at my desired rpm (6k or 6100) on the spray. was on a 2.73 gear now a 3.42 gear.
ran nitto's for a while when i was on motor, would NEVER go back to them.
Old Feb 25, 2007 | 07:28 PM
Getav8's Avatar
So you did break into tens on a 255-50-15 MT radial?
If so what suspension setup are you running.
Old Feb 27, 2007 | 10:43 PM
Got Me SOM's Avatar
i did on a 17 in radial on my stock SS rims with a lowered car with heavy *** 18's in the front.
Old Feb 28, 2007 | 08:41 AM
Getav8's Avatar
So you were on a 275 drag radial?
Old Feb 28, 2007 | 11:02 AM
Got Me SOM's Avatar
Yea a 275/40/17 BFG drag radial.
Now I might run a 275/50/15 M/T radial for better acceleration.
Old Mar 1, 2007 | 01:27 PM
Getav8's Avatar
Just noticed, you are a automatic.
I am going to go to a 17 315 35 bfg to see if that will do it.
Old Mar 1, 2007 | 10:03 PM
WE TODD DID's Avatar
1.48 60'
6.38 1/8
9.98 @129 1/4
M/T drag radial
255-50-16
3100lbs
Old Mar 2, 2007 | 08:58 AM
TeEnAgE pHeNoM's Avatar
Originally Posted by WE TODD DID
1.48 60'
6.38 1/8
9.98 @129 1/4
M/T drag radial
255-50-16
3100lbs
Props for the way you have the suspension set up on you car. Before I sold my car I used to trap 131MPH and only run 10.60's.
Old Mar 2, 2007 | 07:05 PM
Keep in mind that it isn't a chevrolet, its a mustang.
Old Mar 17, 2007 | 11:30 PM
TERMINAL VELOCITY's Avatar
M/T 275/40/17 10.23 @ 129 3700+ lbs
