Corvettes in the 10's?!?!
DTE Brace for the rear.
Lingenfelter hardened drivers side half shaft.
Spec 3+ Clutch with upgraded hydraulics and steel flywheel.
Short throw shifter.
LT Headers and full O/R exhaust.
LS6 intake and TB.
SLP BlackWing Air intake
Im about to install a cam to the tune of 237/241 - .608/.611 - 112 LSA along with the supporting mods like springs and hardened pushrods and such.
I wanna know what problems I will incur on my quest into the 10's with this car.
Thanks in advanced for any info thats shared.
Daniel
2000 FRC all motor with hardened output shaft, 4:10's with over 250 high rpm track launches on ET Streets, no problem with rearend. Good Luck!
LS6 intake and TB.
Daniel
10's can be had with about 400rwhp/gears alot of seat time and a good 60'. It 's much more challenging to run 10's full weight with stock suspension.
I dont think I will be doing gears anytime soon. Im sticking a big cam in it next week and we will see where that takes me. Heads and nitrous will be next month or June. Its been to the track once this season, still has some issues to be lined out. Hes running a single turbo setup this year, but ran the first test passes on the Nitrous convertor from last year. Went 10.85 @ 126. TC was flashing to 5500 or so. New stall is much tighter, so should run deeper into the 10s now.
The following year added Dart 225 heads and fast lsx intake and went 10.7
This year with a 402 LS2 and just a few passes we are at 10.51
Not sure what area you are in but if you are near NJ, this will be the weekend at E-town to check out 10-second Vettes
i/c maggy @ 7lbs,
rpm a4,
yank 2800 (10.89-10.99)
vig 3200 (bested 10.66)
lpe output,
mt et dr's (275/40/17's @ 16-17lbs)
very consistent 1.5 to 1.6 shorts
pump gas
EDIT: more than full wght, added i/c maggy and 6pt rollbar
best pull of 10.66@128.5 1.55 short
http://img.photobucket.com/albums/v7...ff/10sbaby.jpg
best short: 1.32 (dont pay attention to the et, car lifted and came down hard, thought i broke something *again* and i just pedal'd it off the track)
no damage..woot!
http://img.photobucket.com/albums/v7...ftnegative.jpg
im totally kicking myself for selling it last sept.....idiotic move of the decade.
