10 Second Club Now you are haulin! 10s are sweet
best 60 ft stock rear.
Old 07-13-2007, 03:03 PM
  #61
CamaroSS's Avatar
Make that a 1.48 now.
Old 07-30-2007, 10:56 PM
  #62
mulot30th's Avatar
Best on a 10 bolt was 1.6X
Old 07-31-2007, 08:31 AM
  #63
Travis99LS1's Avatar
LOL you guys all suck...somehow i managed to break my'n on a 2.0 60ft with 2.73's gears haha....I have another 10 bolt in there with 3.42's..and i just put a 3000 stall in there too...so ive been scared to go to the track..but now after seeing all you guys pulling crazy 60ft's on the stock one..i might say **** it and go anyways...
Old 07-31-2007, 05:29 PM
  #64
tha joker's Avatar
1.53 and lots of 1.57's with a 6 speed gto..stock rear,stock bottom end ,and stock t56 and still going strong..
Old 07-31-2007, 10:09 PM
  #65
BriancWS6's Avatar
In my previous auto car the stock 10 bolt went 1.6s with no problems.
Last Nov I demolished the spider gears in my current ride (M6) on the 1-2 shift The car coasted the 1/4 in 31 seconds from 1st gears momentum
The lowest it went before it broke was 1.75 on Nittos, and I never had any wheel hop.
Old 08-01-2007, 05:49 PM
  #66
phantomLT1's Avatar
Default I wish I had an auto on the track>
My traps are constant 90 to 91 mph on a 100 shot in the 1/8 but my best 60 ft time is 2.23. I would like to know the best 60 ft times for a 6 speed car. That was on a stock 4.10 gear rear end with some shitty Nitto DR. Just bought a 12 bolt and getting MT ET streets I have seen cars run 7.60's with my mph hopefully it will happen.
Old 08-02-2007, 08:50 PM
  #67
ZV8
ZV8's Avatar
I have a stock 10bolt with a cover and 3.73 gears in it with countless 1.7X-1.9X 60fts and quite a few 1.66+ times with 255/50/16 MT ET DR streets and 315/35/17 Nitto555R DR's and it has very minimul almost normal rear end howl in it. A4 with 4000 stall in it.
Old 08-30-2007, 01:04 PM
  #68
Bersaglieri's Avatar
Guess I'll just weld the tube and throw a girdle on my 10 bolt and pray for the best. Prettty encouraging results for auto guys like me.
-Dustin-
Old 08-30-2007, 01:43 PM
  #69
jessedale98's Avatar
1.59 60ft.
Old 08-31-2007, 03:57 AM
  #70
waterbug1999's Avatar
This ought to be a "sticky" as far as ten bolts are concerned.. I
ripped a 1.45 60' on my 10 bolt and I plan on either bolwn it up, or gettin a 1.3X. Time will tell.
Old 09-06-2007, 10:34 AM
  #71
NickcZ28's Avatar
1.53 NA-1.4X N2O
Stock with 4.10's
Still holding
Old 09-16-2007, 01:58 PM
  #72
98REDZ's Avatar
1.56 for me,...N/A but forged and ready to spray before too long, Also on completely stock suspension other than !swaybar. 3.73 gears & 4K stall
Old 09-18-2007, 03:35 PM
  #73
LS1 SPEED's Avatar
going back out Sunday
We put some Welds on the car with a 275/50/15 and either it goes well in the 1.4's or it's breaking.
The rearend end make a little noise, but nothing too bad. I am sure that will change when we spray it out of the hole
Old 09-19-2007, 07:22 PM
  #74
SnakesRslow's Avatar
went 1.6x many times on a 2800 stall and slipping tranny. With the new tranny and 3800 yank im hoping to go high 1.4 low 1.5's on the howling 10 bolt haha. ps has aftermarket 3.73 gears
Old 09-20-2007, 02:03 AM
  #75
99DWPTA's Avatar
1,7-street tire 3.23
Old 09-20-2007, 02:40 AM
  #76
87__TA's Avatar
1.42 N/A
1.38 Spraying at 15 mph.
3.73s, torsion diff, Moser street axles. Stock cover.
Same rear since 2002 when I began modding car.
This year finally cracked Torsion, but may have happened when I totaled
that car last year.. not sure.
Same rear resides in a new chassis.
Old 09-20-2007, 03:15 PM
  #77
What do you guys suggest as the best modifications to help one hold? I see some people using the stock rear covers and some using aftermarket ones...is it worth the $150? Or is the money better spent elsewhere? I'm $1k away from a 9in...
-Dustin-
Old 09-20-2007, 03:20 PM
  #78
98REDZ's Avatar
Save your $1K & get the 9in, cross your fingers, and race it! Thats my suggestion, your in an auto,...MUCH better off than a M6 car with a stock 10bolt.
Old 09-23-2007, 03:51 AM
  #79
Well, have not read thru all the 60' times.. But, I know mine is up there running a 1.45 60'.. And , in 2 weeks its gettin the test. upping the shot to a 150, and if that goes good, then the 200 shot and see what happens! So, wish me luck! Damn, a 1.3X 60' on a 10 bolt? We shall see.
Old 07-15-2008, 09:14 AM
  #80
s346k's Avatar
mattd did it.
Quick Reply: best 60 ft stock rear.
