10 Second Club Now you are haulin! 10s are sweet
Is this good enough for a 10 sec. Slip?
Old May 21, 2007 | 05:40 PM
dan03mach's Avatar
9 Sec. Club!!!
Default Is this good enough for a 10 sec. Slip?
I went to the local 1/8th mile track the other day and ran a 6.92@102.49... I was running on 26" ET Drags with 3.73 gears, rowing the gears.. Race weight was 3420lbs with driver.. I was also running out of gear a little before the finish line so I think I would have ran alot better on some 28" ET Drags.. They were also spinning pretty bad out of the hole, 60ft's were 1.53's... What do you guys thing this run would have been in the 1/4?
Here is one of the other vids I have..
Thanks Dan
Old May 22, 2007 | 03:37 PM
1936FordPU's Avatar
Originally Posted by dan03mach
I went to the local 1/8th mile track the other day and ran a 6.94@102.49... I was running on 26" ET Drags with 3.73 gears rolling the gears.. Race weight was 3420lbs with driver.. I was also running out of gear a little before the finish line so I think I would have ran alot better on some 28" ET Drags.. They were also spinning pretty bad out of the hole, 60ft's were 1.53's... What do you guys thing this run would have been in the 1/4?
Thanks Dan
What is rolling the gears like?
Old May 22, 2007 | 05:12 PM
dan03mach's Avatar
9 Sec. Club!!!
Shut it Mike, damn drunk typing.. LOL you know what I ment..
Old May 22, 2007 | 08:43 PM
Smokinstorm's Avatar
Old Drag Racer
Damn Dan, that's a fantastic MPH for that time. My 6.86 @ 100.5 turned into a 10.76 @ 126 so with your extra MPH I'm confident you'd motor past me in a 1/4 mile. I'd bet you'd be running some low 10.70's or even some high 10.60's given that 660' effort. What shot are you spraying to run this?
Also, just curious, do you think the spinning you did out of the hole added a little MPH to your run that might not have been there otherwise. I only ask because I ran over 102 in the 1/8th when my car spun out of the hole some.
Old May 23, 2007 | 04:49 AM
dan03mach's Avatar
9 Sec. Club!!!
Well they say spinning out of the hole adds a little mph but the car is making alot of power and I was running out of gear before the trap and the n20 cut off before then too.. I was running a little over 7K rpms at the trap and the n20 cut off at 6.6K so I don' t know for sure.. I had the 200 pills in it at the time.. I'm guessing the car was make around 530rwhp and over 600rwtq. on the 175 pills it put down 510 and 600 on pump gas. I had 110 in the tank at the time of these runs. I really needed some 28" tires to get a full run on the n20.. I'm pretty sure it would be close to a 6.7 run with the bigger tires..
The only thing about your times and mine is that you have an A4 and I have a 5 spd.. You will run a better time the I would just because of that.. but I can drive a 5 spd pretty good.. My guess it would be in the mid to upper 10.8's..
Old May 23, 2007 | 07:17 AM
1936FordPU's Avatar
This is Matt brother. Mike was in the garage last night working when I posted that.
Old Jun 5, 2007 | 07:11 PM
Mach1_Marauder's Avatar
I'll be running 8s before Dan runs 10s!!!
Old Jun 14, 2007 | 04:44 PM
00 Freak's Avatar
I don't think you would've made a 10sec pass. Because if your about to run out of gears then you would be running alot slower the other half of the track. That would be my opinion. But nice 1/8 times though. There another nasty 5spd Mach 1 in Ft. Worth I want to race that runs 6.8s. I should be back visiting again in December.
Old Jun 16, 2007 | 06:48 PM
raymond mckinney's Avatar
I ran a 6.99 1/8@ 102mph and 10.94@124mph 1/4 but with a 1.60 60ft. So i would say you're in the 10's for sure.
Old Jun 17, 2007 | 08:57 AM
udlose99ta's Avatar
damn that stang looks sweet on welds! nice car man
Old Jun 26, 2007 | 02:04 PM
dan03mach's Avatar
9 Sec. Club!!!
I wasn't running out of all my gears, just topping out 3rd, I still had all of 4th.
And Bill you went from saying 9's to 8's what is it going to be now 7's LMFAO. Go get your car finished first before you go making claims to times it will run.
Old Jun 28, 2007 | 11:39 AM
BAIN's Avatar
Dan you should be around a high 10. My car ran 6.94@98 and 10.98@122. My car is N/A so you should pull more on the top end with spray.
Old Jun 28, 2007 | 05:45 PM
carado1984's Avatar
sounds like its time to throw some 325/50 et street radials on those welds.
Old Jun 29, 2007 | 12:26 PM
silverbeast's Avatar
I come up with a 10.86 on that 6.92 pass. nice times. Are you spraying that big of a shot on a stock bottom end? Anyway car looked good going down the track. good luck
Old Jun 29, 2007 | 02:24 PM
rufretic's Avatar
Man your car launches hard, looks good. I think you can make it in the 10.8s at least, as long as the n2o doesn't cut off at the 1/8 lol.
Old Jun 29, 2007 | 05:51 PM
zmonsterjb's Avatar
sweet sweet.
Old Jun 29, 2007 | 05:52 PM
zmonsterjb's Avatar
what rpm are launchin at?
