10 Second Club Now you are haulin! 10s are sweet
A couple things for a 10 second pass
Old Feb 29, 2008 | 03:01 AM
LSGunZ28's Avatar
Default A couple things for a 10 second pass
#1 What kind of roll cage is required for 10s? Im from California and I wanna run a 5 pt rollcage from DOM steel(Im unsure what this means, but I was told chromemoly or just a better steel?) anyways I was told under 11.49 I will need a 5pt rollcage and its good til 10.00s
is this accurate?
what about relocating my battery, why do I need a switch?
what kind of harness is going to be necessary
I will have my stocker 3pt, but also have a 5 pt harness installed, how should these be installed? from the bar or the ground?
lastly, a rough estimate, what will I be running in a M6, 3.73 camaro making over 470rwhp? the weight should be right at 3400lbs without the driver included 250lbs...
I used to be lighter, but the cage will add eight unforunately...
I know with 364rwhp , slicks and skinnys on bogarts, I ran a 7.84 @ 89.25mph in the 1/8th...
So Im sure that was close to a 12.0 - 11.99 pass or so.... I was cutting high 1.6 . 60's
how much do you think Ill improve my 60's with over 100whp?
Thanks for all the help....
Old Mar 2, 2008 | 05:34 AM
LSGunZ28's Avatar
uruyq
Old Mar 2, 2008 | 08:30 AM
Z28FirefighterI1's Avatar
You'll need a 6pt roll bar idk about the steel I did cromemoly, If you move you battery to the back you will need a kill switch. The shoulder straps for the harness sould be bolted to the roll bar. You'll also need a sfi racing jacket, helmet, longer wheel studs if your running drag rims, trans shield or blanket, sfi flex plate and balancer. As far as your time goes idk you'll have to see if you can still hook with the extra 100hp.
Old Mar 2, 2008 | 02:26 PM
rmata's Avatar
Is it a 5pt minimum for 10s or do you have to have a 6pt?
Old Mar 2, 2008 | 09:08 PM
LSGunZ28's Avatar
I never hard 6 pt...
so I need a race jacket, a trans shield? these are all new to me, for a 10 sec pass...
Old Mar 3, 2008 | 03:06 AM
RedsrtAk's Avatar
the only difference between a 5 and 6 point cage is the slung bar on the passenger side. Your correct all you need is a 5 point....until you start knocking on the 9's. Race jacket, blanket/scatter shield, dot/snell approved helmet etc etc is also needed and up to date harnesses are also needed....I might be forgetting a few things
Old Mar 4, 2008 | 01:25 PM
Camaro69Racing's Avatar
dont forget the drive shaft drive shaft loop, snell 2000 or better helmet, sfi 3.2A/1 jacket, if you reloacted the battery to the back you have to also have a battery box, the blue morroso box is the best imo and is nhra cert
Old Mar 12, 2008 | 01:39 AM
LSGunZ28's Avatar
how the hell can they tell if I have a scatter shield? I have a Driveshaft loop and Ill be getting new harnesses in the 5pt.. . and my helmet is fine as well..
also there is lug nut rules, etc...
So I just need the scatter shield, blanket(??) , and approved jacket
Old Mar 12, 2008 | 09:06 AM
firefighter813x's Avatar
I would just look up the regs at the local track.
Old Apr 2, 2008 | 04:04 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
you dont have a scattershield, you need to get either a quicktime or mccleud bellhousing which is a scattershield and is sfi certed
Old Apr 11, 2008 | 11:59 AM
jmill96Z's Avatar
You also need an SFI balancer
Old Apr 21, 2008 | 04:59 PM
LSGunZ28's Avatar
have a powerbond
Old Apr 27, 2008 | 06:26 PM
COOKIE MONSTER's Avatar
Are powerbonds SFI apporved?
Old May 3, 2008 | 12:12 AM
SleeperZzZ28's Avatar
yea I just bought one and its has SFI approved on it or some crap. I just looked at the thing the other day when I was clear coating it.
Old May 7, 2008 | 10:44 AM
NosboySS's Avatar
Metal valave stems also. Found out last time I was running
Old May 11, 2008 | 06:21 PM
jason02Z's Avatar
Axel's and tranny blanket too.. im going for tens this year and its adding up cost to much haha.. i put my money in HP first. but its a street car still
Old May 13, 2008 | 11:32 PM
TWS's Avatar
TWS
I was going to add that. The tech inspector got on my case about it last trip to the track. I kinda thought WTF? No track has ever harrassed me about that until now.
I'm hoping that I can get away with my current rubber ones until it's time for new tires.
Old May 14, 2008 | 05:37 PM
NosboySS's Avatar
Tubes come with metal valve stems, but you have to drill out the hole alittle before bringing them to a tire shop cause they wont do it for liability purposes. Saves you from 2 trips to the tire shop
Old Jun 9, 2008 | 06:52 PM
LSGunZ28's Avatar
These rules are gay!
some of them, then again I dont blame them. a lot of shitty ricers go and spill oil at the track ruining it for us...
Will 480rwhp @ 3650 raceweight(with me in it) and 3.73s on slicks and skinnys run 10s???
the 480rwhp is an estimate and my car maaaay weigh less than 3650, if Im lucky...
probably at a 3390 now and Im 265lbs... Im also gonna put in a rollcage, but maybe do some other stuff to save weight.
Old Jun 10, 2008 | 12:41 PM
ndfrsd6's Avatar
these rules are there for a reason ......i really would not want my driveshaft to go through my floor or my car or clucth go through in to the cabin of the car .....it happened to a friend of mine his clutch went into the car and cut his break pedal off !!!! when you go this fast saftey should be first
