Finally in the 11s
You need a better 60'
weight reduction...whats your race weight? mine was 3450 raceweight.
what tires? do a good burnout. pump fronts to max and rears with most psi that allows you to hook.
are you aware of shallow staging? look it up. it makes a difference.
practice what the stall likes. off idle or a load of 1200-1500 rpm seems to do it for my car.
swaybar...my car pulled front left wheel an inch off ground when car did 11.9stock internal bolt on only.
a good cai. ssra gave my car 2 tenth when it was bolt on only stock stall.
IDK the specs of that cam but either way I think theres a **** ton left in your car.
Just looked at your mph and seems low. What was da?
Race weight is 3500 lbs
My trans/verter actually let go two days later.
Running Toyo Proxes TQ 315/35/17s
I agree on the mph. Car only dyno'd 361hp
I have a FTRA
My 11.9 was after doing my best burnout and prestalling to 1200-1400 Roma and then rolling into it.
I broke out so I couldn't try to beat that.
I have a FTRA
