Made it into the High, High 11's
Made it into 11's, by skin of her teeth.
360 RWHP, from GM LS3 376CI 480 HP rated Hot Cam crate engine.
3.55 Rear gear ratio. TCI 6X trans. Cricle D converter stalled at about stock RPM
Street tires, no DR's
Car as run with dirver weight after run 3564 LBs, without driver 3,339 LBs with less 1/4 tank of fuel.
