Hoping for low 12s and landed several 11s from stock internals.
Originally Posted by WJ SOM SS
01 B4C: FYI, Your car is 1 of 47 white automatic B4C car produced in '01. Only 6 M6 white B4C's were made in '01. Keep it white..... WJ
jt
Fleet paint #'s......might be hard to find that out. Get some more weight off that car, if you can. Not sure what sub-frame connectors will add for pounds, that's why I suggested the airbag first----it's cheap and doesn't add any more weight. Best. WJ
SFC will add weight, but if I could get the car to leave better the benefit will outweigh the additional weight. Oh yea, I have to definitely start looking into some weight reduction tricks. Any ideas or suggestions? I was thinking about a K member and A arms.
jt
jt
'01 B4C: There's a great itemized weight reduction on this site somewhere....Pro Stock John made it up, I believe....You should also get ahold of some ET Drags. Either 15x8.5's or 15x10's. I have the 8.5's----way better hook than ET Streets....WJ
WJ, here it is!
Weight reduction list!!!
https://ls1tech.com/forums/drag-racing-tech/17319-weight-reduction-list.html
Thanks jt
