11's on stock rear end??
I went 11.21 @ 121.30 with a 1.58 60 ft. I had a Small Cam, TCI 3500 Stall, 3.42 gears, Lt Headers. Cutout and a little Juice.
But I have made several 11 sec passes on mine though.....
I have a new set up now....
11.47 @ 120 for me with a 1.60 60 ft....
a4 4000 stall 373 with the auburn pro series and a ta girdle in the stock 10bolt for know probably 40 plus passes so far...275/45/17 mt et street radials....big cam.heads more cubes..etc etc
full weight with me..3750 ..me = 275 of that
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
I am right at that level of hitting 11's and the rear just broke. It was the carrier. I had just put motive 4.11's and a TA cover on it, now it's time for a 9".
I was very hard on the rear though! ET streets and 3500-4000 dumps.
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
I made 15 passes or so in the 11's, it was more the low 1.5x 60's the 10 bolt didn't like! Mine took a dump finally and I went with a 12 bolt. 1BAD98LS1 has been running in the real low 12's all year (with two 11 sec passes) on his 10 bolt with 4:10's, but I don't see it lasting much longer!
