could i run 11s
i have a friend w/ the same set up, except he had a 150hp shot, at hrp ( at sea level) went 11.4 1.6x 60ft.
If you get a decent launch you could be high 11's. If you spray out of the hole and HOOK you might make mid 11's.
Now that we know what the transmission is, that is definately a possibility. Didn't know the tranny when I posted that.
by the way i have seen a rear end let go on a 12.0 a4 car on the launch, so the horror stories are true.
the way i do it and few others i know that are on stock rear ends is to: leave on motor and get on the gas as quick as possible or as soon as the car hooks. if you hit the gas while your spinnin more than likely you will hit the rev limiter. that can be bad as well. i dont know though if you are on a button or an RPM switch.
Same rear here with C-clip eliminators. I'm sure B-Man has that option as well. It's a tad noisy at cruise but that's probably more about the gear setup than anything. I'd recommend this rear to anyone looking to put down up to around 800 horsepower then the Ford 9" is probably better.
