11 Second Club Snake eyes are a good thing
11.6 @125
Old May 21, 2007 | 09:55 PM
xxtheonlyxx's Avatar
Default 11.6 @125
Finally broke into the 11's on my small jets (in 90 degree weather with no traction). Next time out I'm going to the medium jets, and hopefully will be able to get enough traction to spray off the line. Next stop 10's....
90/90 combo
AFR heads
Com Cams custom grind
QTP long tubes
NX wet kit
NOS progressive controller (set to spray an 80 shot on that pass)
Umi suspension
ET drags
Rossler terminator 3 transmission with trans brake
Yank 3600 stall
Strange 10 bolt rear. 3:73 gears
Video
Old May 21, 2007 | 10:14 PM
5_02ls1's Avatar
nice shifting you could hear when you started spraying..
nice run
Old May 21, 2007 | 10:15 PM
nice run
Thanks!
Old May 21, 2007 | 10:23 PM
waterbug1999's Avatar
You cant hook those ET drags?
That 1.86 60' is low IMO and should be at least in the 1.5's with your mods... If you can do that, I think its got a potential for a low 11 or high 10 sec pass.
Old May 22, 2007 | 06:46 PM
It was like racing on ice. I gave up on using the trans brake and started foot braking. I had to launch under 2k to get them to catch. The car has 60' 1.6/1.7 on radials in the past
If I turn my progressive controller up to 100% a 10 is a definite. I just need better track conditions so I can spray off the line and not in 2nd gear. It was so squirley at the end that I was scared to spray higher than 50%.
Old May 22, 2007 | 07:54 PM
Wow, why is the track so shitty? Just bad prep?
Old May 22, 2007 | 08:41 PM
Yeah, and its wierd because its usually the best track out here.
Old May 30, 2007 | 05:15 PM
2000_SS's Avatar
125 mph and you only went 11.6???? DEFINATELY a traction problem, lol. good mph man, that's a 10 sec. car for sure!
Old Jun 3, 2007 | 01:55 PM
traumaxital's Avatar
That TA has alot more potential then you guys know. I am the slow GTO in that vid. That TA is a freak of nature.
Old Jun 3, 2007 | 01:57 PM
02 Camaro SS's Avatar
With that mph in an A4 10s are guaranteed with traction.
