What gears are u 11 sec guys running?
Thanks bad6as for the all the info bro, I was leaning towards the 3.90s and I think for sure I'm going that way. Should have track times once my local track is open in april. Appreciate everyones help
m6, na, 4.30's here with 27x11.5x15 hoosier qtp's. I launch anywhere from 65-7000rpm's. if your rev limiter is only set at 6300 then get the 3.90's or 4.10's. is there a reason your limiter is 6300? where did you make peak power at? you wanna shift a couple hundred rpm's above peak. so bump up that limiter and go with 4.30's.
#40
4.30s in a 35-spline 9" Moser. You are going to lose some power with that rear, but it will be worth it.
Next gear change will be to 4.56s. I plan to run a 27" or 28" tire. Right now I am just south of 500rwhp.
