12 Second Club In the 12s yet? Come inside!
can i join?
Old Oct 26, 2009 | 03:20 PM
98TA6.0's Avatar
Default can i join?
i know i need a serious driver mod but here's the result from a night of shake down runs.
R/T .530
60' 1.822
330' 5.153
1/8 7.944
MPH 87.43
1000' 10.342
1/4 12.335
MPH 113.63
here's the video of the 12.33 run
http://s184.photobucket.com/albums/x...t=1233edit.flv
Old Oct 26, 2009 | 03:58 PM
Magnet's Avatar
Decent run, get a clean run and it should be more impressive What tires are you using? A good amount of spin, and seemed hard to get in gear..
Old Oct 26, 2009 | 04:23 PM
98TA6.0's Avatar
they were an old set of 26x11.50 MT ET Streets. my tranny has been acting up. i'm using a new GM slave and master on a Monster Stage 5 so disengement is a hassle. looking to go Tick pretty soon. i'm going to a set of 28" MT ET Streets next time to clean up the run.
Old Oct 26, 2009 | 07:47 PM
Magnet's Avatar
sounds good.. I have the monster stage 3 and tick master, you will like it I woulnd't be surprised to see some solid 11's if you get that stuff figured out..
Old Nov 18, 2009 | 10:52 AM
98TA6.0's Avatar
i'm curious. i have been cutting consistent low 1.7s but i cant seem to get out of the 12s. my mph is way too low for low 12s. i ran a 12.1 @109 mph with a 1.72 60'. what's the deal? i found a problem with my tune and corrected it so it shoudl help my trap a bit. the limiter was set at 5900 so i stepped it to 7500. hopefully 11s this next time out.
Old Nov 18, 2009 | 12:22 PM
Magnet's Avatar
I wouldn't rev even near 7500 if your on stock pushrods/springs... you will be pushing the stock shortblock revving that high as well...
Weather could be affecting your trap speed, but if its not that then it seems like you may be a bit down on power since you trapped 113+ before... you could have easily bent a strock pushrod or something revving that high..
Old Nov 18, 2009 | 12:28 PM
radchevy's Avatar
I would stay with a 26" tall tire I believe Micky makes a 275/50/15. If go to a 28' it will take a way your gear and kill your 6 foot.
Old Nov 18, 2009 | 04:04 PM
98TA6.0's Avatar
it's a forged 6.0 bottom end with an MS3 cam and Isky double valve springs.
Old Nov 18, 2009 | 04:57 PM
DREAMZ28's Avatar
Sound's like you short shifted 3rd.
Could've taken a bit off the top end.
Old Nov 18, 2009 | 05:35 PM
Magnet's Avatar
oh wow... I would get it checked out personally...109 is slow for a MS3 cammed 6.0...I went 116.8 with bolt-ons..
