12.6@114
Was about 35 degrees outside, and with a few runs I couldn't figure out where to launch at...
ran a few 12.62-64 range at 113/114 with 2.0 and 1.95 60's.
Car has VRX5 cam, FAST intake/TB, 12 bolt/4:10s, drag radials and LCAs.
I'm sure it's capable of low 12s easy with this combo, I'll just need more seat time.
Each time I got a good 60' I missed a gear
Those low 1.8 passes would have been low 12-second passes most likely, probably 12.3 range with that trap speed if I had to guess.
Also, what was the DA?
It's not a stock clutch- the original owner was going to put a blower on it, so he put the 12 bolt in along with a heavy *** clutch. Again, I have no idea what type it is...
I'm also having trouble deciding where to shift RPM wise...
on my dyno sheet, the power peaks at 6250rpm, but stays flat until like 6700rpm...my raptor is set to 6500, but I often shift a little before it goes off...
thoughts?
