12.73 soft launching
i just ran this time at orlando speed world, my 60ft was a 1.87. i brought the car to about 1200rpm and slowly got onto it and ran a 12.73@108 next run i brought the car to 1500 and floored it and spun got a 1.94 60 and ran a 12.87im running 26x9.50x16 hoosier qtp dr's at 17 psi, if anyone can tell me how to launch better with the coan racing 3200 stall id greatly appreciate it thanks.
Might try power braking up to 1500 rpm, then instead of stomping on it, roll the throttle in somewhat quickly. If you have gears other than factory I would go 1200 rpm. No matter what, once your tack rolls past the 3200 stall speed, floor it. You don't want dead air take off where tb plate goes from cracked to wide open. Definetly get the tires smoking somehow.
i did exactly what u just told me to do with the 1500rpm then rolling into throttle and got the 1.87 60ft, i think next time im going to do a long burnout and try the 1500 launch then try it at 2000 or higher if i can.
Yeah make sure you do a good burn out,don't be scared to heat those things up,and like someone said drop your tire pressure down to 14,15.have fun with the spray but getting your launch down ,and getting the tires warm enough should be goal one,take care man happy holidays
