12.38 @ 109 / 1.7 60'
Ran a best of 12.38 @ 109, 1.709 60'.
_______________________________________________
01 Firebird Formula A4, cloth int, t-tops
Motor : 383ci, 11:1 comp, 6-bolt main, windage tray, forged eagle rods, forged mahle pistons, forged crank, '11 CTS-V oil pump, Magnum 5/16 pushrods, dual valvesprings w/ti retainers, LS6 intake, '02 ZO6 heads, competition valve job, LS6 cam, K&N intake, 255 lph fuel pump, stock exhaust
Driveline : FTI 3500, built 4L60E, big trans cooler, PST 3.5' driveshaft, 1350 yoke, Strange S60 4.10
Suspension : BMR k-member, BMR upper&lower front CA, BMR rear lower CA, adj torque arm, panhard bar, stock struts
Running NT555R 315/35R17 on the back
Dynos in at 330 rwhp / 342 rwtq unlocked
Yes, the car in the sig ran that time. It was the best out of 9 that night, with 12.4's the other times. Trapped 110 one run. Not sure what the DA was, I'm in Orlando and it was about 80 degrees.
I could be wrong, but something seems really off about your times, and the numbers in your sig. I'm running times a fraction faster than that with a stock cube, stock internal, bolt on LS1 with a 4000 stall. With the list of mods you have in your sig, I definitely think your car should be pushing higher numbers, and should be getting into the 11s at the track, especially on drag radials.
The stock exhaust could be choking you off maybe? That's the only thing I can think of. Even a high DA shouldn't limit you that much.
Wow, all kinds of replies!
Well, to start off, the 383 was really held back by the stock ls6 cam and stock exhaust. That's why it made 330 at the tire. Besides the 383 bottom end, it was pretty much a bone-stock ls6 top end with no bolt-ons whatsoever. It has been thoroughly tuned by Geoff at Next Level Performance.
The 3500 is a very street friendly, low STR and tight converter. That best run was launching at 2000 rpm and somehow getting it right for that 1.7 60'. Besides the stock struts, all other suspension mods should help with the hookup running a 4.10. First gear was over in an instant, but made up for it with an incredible blast of take-off.
Here's all nine track times that night, including the failed launches:
In addition to the above post, I have just recently had a cam and exhaust installed. That woke her up! We'll see what that does at the track next Friday.
-Comp Cams 230/236 114+4 XER
-American Racing 1-3/4" LTs, 3" collectors, 3" y-pipe w/high flow cats, 3" manual cutout
-42 lb injectors
-Dual Valvesprings w/ti retainers
RED is before the cam+exhaust. BLUE is, of course, pretty awesome:
-42 lb injectors
Not to get off topic and be moved into the " Dyno Guesses and Bench Racing Forum", but I've been guessing at 11.7 @ 118, just to throw a number out there. That will include running 3rd gear out to 6500 rpm at 110 before clicking into OD. That's how I ran that 110 trap speed, originally.
Yeah, I've heard about these cam only cars making big numbers and respectable runs. Most of what I've spent is on overbuilding to survive my right foot. I'm sure everyone can understand that! Not to mention all the parts I have broken already, ie stock 10-bolt w/4.10 gear, and stock valvesprings that ruined the original LS1. good times
