Another new PB 12.32 at 111mph
Well the old girl still has it and maybe more, 1/2 tank 20psi and the new tune.
1st pass 1.756 60ft 1/8 7.878 at 88.40 1/4 12.342 at 110.40
2nd pass 1.825 60ft 1/8 7.892 at 88.39 1/4 12.321 at 111.37
3rd pass 1.756 60ft 1/8 7.875 at 88.64 1/4 12.325 at 110.66
I ran 2 more times but no traction 12.5 at 110xx
I am going to take the front SB off and run the Hoosiers next time.
Ended up putting the ssra back on of course
https://ls1tech.com/forums/drag-raci...oof-works.html
Before the converter I deadhooked with them and they kind of slowed me down.
Do a real good burnout. I did the 11.9s stock internal, bolt ons, and ss3600 with 32psi in my mt drs. Never touched tire pressure
Stock suspension and everything else. It wasnt even very warm. DA was -187 AND on a street night with **** track prep
No 11's until I get some weight reduction.
If you get that ssra ill bet you that you will be closer to 11s than you think. A -1000 da and a ssra ill bet you can break 11s. Also, if you have not run without the swaybar yet then thats another plus. I poped the front left tire when my car broke 11s that night with swaybar delete.
Your right about the 11s but my main reason for posting that was about tire pressure.
