12.7 at 114 at NYIRP
It's a bolt-on ls6 dude. The weight of the car is in the low 30xx on that run. The power in the sig is accurate though a little low because of the dyno dynamics. It would make about 431hp and 408tq on a dynojet.
I have the same platform. I got a brand new LS6, 2,000 miles now on the clock.
I have PRC Heads, Cam, FAST 102/92, 85mm MAF , 1-7/8" LT, true duals, no CATS, (Now an UDP),
Produced 455 RWHP. I'm not even close to that trap speed and your just a bolt-on.... I need to weigh my car, but can't be over 3300lbs
Are you a auto? Is your 102 ported? Gear? Any aero mods?
I don't contribute my trap to any one thing. Mostly lots of little bits. More than likely it should go up with a better launch. I'm a m6 btw.
Your MPH is good for mid to low 10s.
