12 Second Club In the 12s yet? Come inside!
Mid 12's here
Old Feb 19, 2014 | 01:32 AM
sWcCuZ's Avatar
Default Mid 12's here
2.01(60')
12.58@112.58
I only was able to get one run in. I completly let up on throttle because I got excited and blew tires through first. 2nd gear hooked and felt good from ther on. After that my starter broke and chewed my $300 dollar tci flywheel up
For what i have in this car i think the car will go much faster. but this was my first run out.
Heres my parts list:
1998 Pontiac Firebird Forumla, LS1-383 eagle racing strocker, Lingenfelter Wieand intake, 44lbs Edelbrock injectors, BBS power plus 80mm throttle body,
complete Aeromotive A1000 fuel system, 4L60e trans with 3000 stall, Suspension:Eibach sway bars, BMR torque arm, welded sub frame connectors, lowered coil springs/kby adjustable shocks,complete wilwood brake system with 6 piston calipers and 2 piece oversized drilled and slotted rotors, SSBB brake proportioning valve, 373 moser 9" ford rear end,
fronts Nitto 275/40zr17,rear:Nitto 555 extreme zr 315/35zr17.
Also 200hp nitrious outlet plate. But have not sprayed yet. Need to get motor tuned first.
What you think gurus?
Old Feb 19, 2014 | 09:03 AM
HCI2000SS's Avatar
Not sure what cam is in it, but you should have a lot more left in it lol
