2001 Pontiac Trans Am
I have a 2001 Pontiac Trans Am. I bought it December of 2016.
Mods that car came with, Volant cold air intake, BBk longtube headers ory and slp Lm1 exhaust. And a Yank ss3600 converter.
I put Moser Fab 9 w 4.11 gears with wave track posi. Moser double adjustable lca's, and double adjustable pan hard bar and torque arm. Bmr anti roll bar, Bmr sub frame connectors and driveshaft safety loop. Weld rts 71 black 17x9 with 275/40/17 Mickey Thompsons frt, 17x10.5 with 315/35/17 Mickey Thompson Et street Drag radials.
Best et is 12.608 @ 106.99 mph dyno at 336rwhp
Sorry the et was supposed to be 12.608.
temp was 61 degrees
barometer was 30.12
I have to tune the trans because at about the 1000 ft it shifted to 4th.
60 ft was 1.762. The best my car has ever 60ft is 1.73
temp was 61 degrees
barometer was 30.12
most of the 11 & 12 sec stalled auto cars you see on here are on the stock 10 bolt , he is on a 9" here so it weighs more and more parasitic loss - its great that you have a rear in place to take big power but it will take more mods to get the results of a 7.5" 10 bolt car. Wheels are heavier than stock as well same deal lets say you also have a sub and amp , again more weight it all adds up.
I haven't done any engine mods yet. I am doing all supporting mods for the new engine and trans combo. I do have 2 subs and amp in the rear. the car weights 3775 with driver right now. I am going to try and lighten it up over the winter and do front control arms and coil overs front and rear. I will also have a drag wheel set up. The wheels and tires on it now is the street set up. and I left at 1100rpm. Going to work on that next year. I only got it to the track 2 times this year.
The MPH does seem a bit low despite all else. I assume the car is tuned? A friend of mine has a Sunset Orange WS6 like yours with the same mods, but with the stock 10 bolt and 3.23 gear. With big 315/33/17 wheels and MR dr's he ran 12.3 at 111. His raceweight is very similar to yours
Here is an update. The only changes to my car over the winter are putting front weld racing rts 71 17X4.5 with 26x6x17 Mickey Thompson radials, Chrs1313 ac intake set up and retuned the car on the dyno. I made 12 passes last year in the car. I have 6 passes this year so far. Friday on my second pass made the fastest pass so far 12.2961 @ 110.43mph. I have in the picture the time slip and the weather.
I will be at Pontiac Nationals this year. this was my first time running at 42. Usually I go to Norwalk. I am in Columbia Station. Are you going out to Pontiac Nationals. Where are you located?
