Low 12s first time out
best pass was 12.1@112
I sold an engine to a guy with the same kind of car as mine and he lost almost 15 mph because he spun tires past the 1/8 mile. Just wasn't used to that much torque and all he needs is seat time.
Was able to get back out to the track last night. Best time was 12.021 @ 114.08
Definitely had traction issues on the first run (12.7, tires at 19psi), I lowered them down to 17 by the last run but did not see a noticeable 60ft improvement.
I don't know what the Previous Owner had changed since his 11.5 run (1.5 60ft), which he never told me about, I found the slip in the glovebox and looked up pics at the track from that night.
He did have slicks and skinnies on (28's), where I have very old heavy OE Wheels knock off vette wheels with M&H drag radials (275/40r17)
On the last run, I gave the converter as much as I could give it, I could feel the tire shake and some spinning.
I have an intermittent erratic idle issue I should probably fix. I thought it was the alternator working hard to charge the battery over the winter, but now it seems to come on once the car is warmed up. Engine idles between 500 and 1000 rpm. Was going to take a video, but it didn't happen this morning, even after I drove for about 30 minutes.
