Elevens may be coming
4200 Yank
4:10 Gears
Bolton Hood 25lbs
Kmember
Light Upper And Lower Ball Joints
Back Seats Were Removed
Corbeau Seats In Front Including Passenger For Runs
Around 1/2 Tank Of Gas (too Much)
Asap Pulley
Shanner Throttle Body
Mail Order Computer Tunning By Allen Futrell
Hal Shocks Front And Back With Front Drag Srings
Carbon Fiber Drive Shaft
Light Weight Front Brakes For Street
Front And Rear Bogard Wheels
26.15.10 Mt Drag Slicks
Full Sized Battery
LANE'S DUAL EXHUAST WITH X PIPE
In The Past At The Track I Was Tearing Up The 4:10 Gears Lauching At 2500 To 3000 Rpm And Setting The Rear Air Pressures At 16. Last Time I Ran The Car Rear Pressures Was Set At 17 And Launch Car Between 1600 And 2000 Rpm's Yeilding Better Times. The Sixty Foots Were Between 1.582 To 1.63. The Temperature Was 73 Degrees In Monroe, Louisiana. Weather Permitting I Am Going Back To The Track This Friday And Rear Air Pressure Will Be Set At 18 To 20 To Assist In Getting More Mph At The End Of The Track--also The Passenger Seat Will Be Removed, There Will Be Less Gas, And Drivers Floor Mat Will Be Removed.
If The Weather Is Good And The Car Hooks, It May Run An Eleven. If I Can Be Of Any Other Assistance Let Me Know. Btw--your Car Is Moving...
Front sway bar is removed. I have FLP headers with true dual exhaust cutoff at the rear axle. My car is a 99 SS camaro with a 02 replacement engine and it has only 4,775 miles on it. I guess the engine is just now breaking in. Anyway if there are any other questions, let me know. Cheers.
Good luck.
