12 Second Club In the 12s yet? Come inside!
Does this qualify?
Old Mar 19, 2006 | 06:31 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Default Does this qualify?
Took the car to the track last night to see how it would run after the cam and stall. The first run was a 7.95 @ 80 with a 1.85 sixty foot. I lifted before I went through the lights. The second run was a little better 7.75 at 90 with a 1.78 sixty foot but I lit the big red eye by .068. The mods are in the sig and it cut the 60 ft times with 245/50/R16 Dayton Daytona street tires at around 34 psi. And yes they only cost $86. She is headed to the dyno tomorrow so see what it's putting down.
Old Mar 20, 2006 | 05:02 AM
bigbadblackws6's Avatar
those times are good for low 12's very high 11's. but it doesnt work like that hear i dont think. good runs tho. i have a similiar setup but a bigger stall on my camaro and im hopin to cut some 1.60's and a 7.70 out of it.
good times tho
steve
Old Mar 20, 2006 | 06:00 AM
Z28/2002's Avatar
The track will be running the 1320 this coming Sunday so I'll post up the slips then. Good luck at the track and if I can cut 1.7s on POS tires then 1.6s for you shouldn't be a problem. You also have 3.23 gears so that will help too.
Old Mar 20, 2006 | 11:44 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
You have to run the times at a 1/4 mile track. Good luck.
Coach
