12 Second Club In the 12s yet? Come inside!
Will I hit 12's
Old Apr 4, 2006 | 12:22 AM
dnm12's Avatar
Default Will I hit 12's
I know some many people post on this site asking but (sorry) do you think I am there? Last year I went for the first time and blew up second gear, and went on this mod spree.
sorry I tried to delete the pointless ones....
-SLP Cold Air Induction
-SLP Air Box Lid
-SLP Smooth Air Bellow
-SLP Line Lock Package
-SLP Skip Shift Eliminator
-SLP TCS (Traction Control) module
-SLP Loud Mouth Exhaust w/3.5" Slash Tips
-Pro 5.0 Quick shifter
-Lou’s short stick for Pro 5.0
-K&N Air Filter
-MSD 8.5MM superconductor sparkplug wires
-NGK TR55 Spark Plugs
-Clutch Masters Stage 1 (12" clutch, pressure plate, input shaft bearing, T.O. bearing, & slave cylinder)
-BMR Tubular Lower Control Arms (polyurethane bushings)
-BMR Adjustable Panhard Rod (polyurethane bushings)
-BMR Adjustable Torque Arm (polyurethane bushings)
-BMR Drive shaft loop
-BMR Tunnel Brace
-BMR Strut Tower Brace
-BMR Torque Arm Relocation Kit
-BMR Boxed Sub-Frame Connectors
-Throttle Body Bypass for coolant
-McLeod Adjustable Master Cylinder
-McLeod High flow Clutch line (no drill mod needed here!)
-RSGear (M6) T-56 17V with Viper yolk
-Motive Performance 4.10 gear set
-TA performance rear end cover
-Jet Hot Long Tube Emission Headers w/ o2 extensions and sims
-Jet Hot Y-pipe
-J&J custom Driveshaft with HD pinion, transmission yolks, & u-joints
-PCMforless.com custom tuned PCM
-New Era Performance Products Ported Throttle Body
-AIR and EGR delete
Old Apr 4, 2006 | 12:36 AM
robb4964's Avatar
If you can drive you might pull mid 12's without to much of a problem. Sticky tires of course.
Old Apr 4, 2006 | 12:39 AM
dnm12's Avatar
really mid 12's I have line lockers so I should be able to get the tires sticky, so 12's should happen if I can drive
Old Apr 5, 2006 | 03:06 PM
linegtdt52's Avatar
I think its high 12's. Most of what you have are bolt ons and dont really show the power gain til you add nitrous, turbo, cam+ heads, etc. Although you have drivetrain. Its doesnt sound like your engine can produce and breathe out the power. maybe a set of ported heads will slip you into the low 12s but without them I think is gonna be 12.8
Old Apr 5, 2006 | 06:32 PM
98TADRIVER's Avatar
I beg to differ, i know i couldve hit at least 12.60s on 245 50 16 street tires before my 10bolt broke
as far as power goes with boltons, 338RWHP 366RWTQ
Click here to see Video
Old Apr 5, 2006 | 06:35 PM
98TADRIVER's Avatar
If you can drive good and get a 1.9 or better 60' you should be able to hit 12.70s consistently. i was on 245 50 16 street tires. slipped clutch quickly at 3500-4krpm ... with stickies and your gears especially i dont see why you cant hit low-mid 12s
Old Apr 5, 2006 | 07:44 PM
Roarin_8's Avatar
His rear isn't gonna last with those 4.10s and sticky tires.
Old Apr 6, 2006 | 07:38 AM
curtisad's Avatar
good luck anyway
Old Apr 6, 2006 | 10:24 AM
dnm12's Avatar
thanks for all the info, yeah the next step is cam, a lot of people seem to waste money on the heads and cam not producing the power for the money IMO, hence i am getting 12's with what I have got and when cam only comes, 11's, my heads should push me down in the low 11's so...heads and cam = 12's is pathetic IMO
Old Apr 6, 2006 | 01:35 PM
358chevycamaro's Avatar
I have LT's an ORY-Pipe, Cut-out, Tune, Air-Lid, and a 4.10 gear in my automatic and spun through second on street tires and hit 12.60's all day long.
A set of sticky tires and I gaurantee that I hit 12.50's or faster pretty easy.
Old Apr 6, 2006 | 01:45 PM
Roarin_8's Avatar
Can't compare the auto's ET with a manual's ET.
Old Apr 21, 2006 | 09:04 PM
dnm12's Avatar
well wish me luck it will be tommarow and the day after I am at the drags, I have some bridgestone potenza's that have been treating me well so far what tire pressure to you all generally drop to? 25 p.s.i.? Thanks again! I hope I make it to the 12's it sure feels like I will!
Old Apr 22, 2006 | 01:06 AM
Roarin_8's Avatar
Leave street tire PSI alone. They don't have soft sidewalls or softer tread compared with drags or slicks. Run the street tires at 35psi and don't do any long burnouts with them either, just do a quick spin to clean them off and you're good to go.
Old Apr 22, 2006 | 10:34 AM
dnm12's Avatar
if tires are sticky then tires are sticky correct??? then stop telling me not to to a burn out, i can heat these tires up till the peel off the pavement why not so i dont spon through 3rd and 4th on the strip!
Old Apr 22, 2006 | 02:33 PM
Roarin_8's Avatar
Street tires use a different compound than drag radials and slicks. But by all means, if you want to do a burnout with street tires go right ahead. Whatever works best for you.
Old Apr 22, 2006 | 03:11 PM
BriancWS6's Avatar
I always heated up my Yokahamas and they gripped better than they did without a burnout. As for the time....I hope you get into the 12s, ****, I ran 12's stock. Going to the track again in a few weeks and shootn for 12.4s or lower with only exhaust, lid, and tb. 12.53 last time out with a sub-par 1.96 60ft. Still has ALOT left in the car. Good luck man!
Old Apr 22, 2006 | 05:26 PM
Camaro Rick's Avatar
Don't forget. 2001's and 2002's had LS6 Intake Manifold's stock too.
Old Apr 22, 2006 | 08:24 PM
dnm12's Avatar
yeah heres a vid of today:
http://media.putfile.com/Good-start-in-14-mile
the track had no traction in it what so ever so i am not going to mention my times because they are disgraceful lets just say in the other two runs the gaurd rail at the 1/8th mile was tryin to get my autograph so i let out of it, so quick question how many of you are running traction control on? or off?
good news my 1/4 times were quicker then the c5 auto vette out there as well as this with a 427 with 460 crank!
Old Apr 22, 2006 | 11:34 PM
BLK02TA's Avatar
Without a doubt run it with the traction control off. I can't beleive you didnt hit 12s!! My uncle ran a 13.1 in his 00 SS M6 bone stock!! With that list of mods you should be well into the 12's!
I myself havent been to the track yet.
Just noticed your on the 245's, all I can say is heat em up real well and don't launch to crazy and it should be no problem.
Old Apr 22, 2006 | 11:39 PM
BLK02TA's Avatar
I can't beleive you spent all that money on the suspension and didnt get new tires/wheels. What gives?
