How did you get your LT1 into the 12's?
Originally Posted by sdm1234
With my mods, I'm running 13.8. With DR's I'll be running 12's???
( Dual Y is good for a couple ponies too )
Since you have a 6-Speed, get some 3.73's or 4.10's.
Next, get a nice CAI.
Unless your car is tired, you should be near 12's.
1 Post
Originally Posted by burnzilla
All you have for power adders are the Loudmouth, Headers and 1.6 Rr's.
Also, I have ram air, so I don't need a CAI.
I think I may be slow because of my tires. I'm getting 2.5 sec 60 ft. times and it won't go any faster than that... My next investment might just be DR's when I can afford them.
The tune doesn't add power?
well thats it right there, get dr and cut a sub 2 sec 60' and you should hit 12's.
Im going to the track sometime at the end of this month or next and im really hoping to hit 12s with my set up + lower control arms, relocation brackets, adj panhard rod, ES torque arm bushing, exhaust cutout, and MSD blaster coil.. i dont know if ill hit it but im really hoping for it
Originally Posted by Michigan Skip
14.40's stock, then 14.00's with a K&N and 3200 converter. Now after adding 4.10's it runs 13.90's. What else to do? LT's gonna drop another whole second?
Tires the whole key to getting these cars into the 12s. You need to HOOK. An otherwise stock LT1 can run 13.5s with LCAs and slicks - seen it done. Add some power adders and you're in the 12s amigos!
my buddy has a 95 z28 all gaskets changed out,
mods are: K&N fipk, trick-flow elbow, airfoil, gm performance rotor cap, msd wires, slp fan switch, factory location flowmaster muffler , and nitto 555r (which he did not worm up at the track). he did a 13.982 @ 99. which i think is good for not having much mods
First of all, every single person on here will have different answers because of numerous variables. Where they live, how well their particular car was taken care of, how well they can drive, etc.
If you listen to Burnzilla then all you have to do is add a CAI & DR's and you'll be straight.
In reality, that's never gonna happen.
From my personal experience (keep in mind mine was an auto), the following mods got me a best of 12.78 @ 106 with my old LT1 in my avatar- LT's, true duals dumped, TH350 swap w/ 2,8k conv., 3.73's w/ big Auburn, CAI, and ET Street's.
Keep in mind my LT1 was a stronger than average runner bone stock. With the stock A4 and 2.73's it ran a best of 13.62 @ 102. It was also a HT stripper car too, so it was lighter than avgerage from the factory.
What you need to do first is take you car to the track to get some baseline runs. That will give you an idea on what you'll need to get in the 12's. If you run 14.2's now, then obviously it's gonna take a lot more than if you turn 13.6's stock.
#32
You sure? I have a 3200 , ET Streets, K&N CAI and only run 14.00's That's with a 2.73 rear gear which should only net me abut 2-3 tenths if I swap it out to a 3.42 or 3.73. LT's would net me over a second?
#33
Originally Posted by COMNBYU
If you listen to Burnzilla then all you have to do is add a CAI & DR's and you'll be straight..
Keep in mind my LT1 was a stronger than average runner bone stock. ..
I'll keep that in mind.
