Barely, but still a 12
Finally broke into the 12's at the EFA meet at MIR. I ran a 12.993 @ 108.58 w/ a 1.93 60'. I have a lid, SLP Loudmouth catback, and a Pro 5.0 shifter. The track was so sticky, that even if i came out at 5k it still hooked and bogged with my M/T dr's. I also had to granny shift third cause on the way home from the meet i found out the shifter stick was soooo loose, but didnt know that when i was running, so every time i tried to hit third it took forever to get in. So I am thinking that if I get a good day when the track is not so sticky and my shifter is tight, I should be able to get a solid 12.8, I guess that is not bad with the mods I have?
Oh yea and a couple days ago I put in a BMR chromoly adjustable torque arm, along with BMR chromoly adjustable lower control arms, and the bolt in lowering brackets. Will that give me another 10th or 2?
Originally Posted by z28misfit
What size drag tire do you run because if I launch at 3k I spin.
