12 Second Club In the 12s yet? Come inside!
Nitto Drag Radials SUCK!
Old 03-07-2007, 05:18 PM
  #81
Roarin_8's Avatar
Picture time!!
Here they are when they were new
New
Last year when I realized that I had too much psi in the driver's side tire.
And now
Driver's side
Passenger's side
I'm gonna see if they hold up till the new water version nitto drs come out near the end of the year.
Old 03-07-2007, 05:53 PM
  #82
LSWaaa?'s Avatar
Mickeys FTW!!!
Old 04-12-2007, 11:10 AM
  #83
tigertales's Avatar
Been worried about the Nitto's as I couldn't hook good on Saturady with them. I think it was acombo of cold track temps and poor prep.
My typical 60' is in the 1.9 range. Car with me in it weighs 3790lbs.
I'v got a SS3600 that I will install over the weekend to hopefully drop those 60's.
After reading this tread I have more confidence in the Nitto's.
Old 04-12-2007, 11:22 AM
  #84
Jordan S.'s Avatar
Nittos arent the best tire, but if you drive your car alot and like to race they are good.
When I had a stock motor my 60 was a 1.7 12.50's all night on nittos.
Old 04-16-2007, 11:13 AM
  #85
Ralls's Avatar
I got a 1.862 out of them. That was in 30 degree weather.
Old 04-16-2007, 11:19 AM
  #86
mattraypharbor's Avatar
1.5 60's all day on nittos.
Old 04-16-2007, 03:01 PM
  #87
1BadZ95's Avatar
Damn! The best I could cut last week was a 2.00 at 15psi with a pretty good burnout. About 40 degree weather.
Old 04-16-2007, 04:13 PM
  #88
darrensls1's Avatar
Wow this is an old thread brought back to life
My best results on 245 Nittos are low 1.7's and dead hooking. This is with 19-21 PSI, 7 second burnout (seven mississippi's after I started seeing smoke) and a quick stage so the tires didn't cool down.
No feathering or finesse required. I would literally mash the gas off idle and dead hook. But in cold weather and or when they started wearing out in the center it was a different story.
I'm trying M/T Street radials this year. I know they won't last as long but I'm hoping to dead hook on colder days and improve my best ET one more time before the 416 goes in
Old 04-16-2007, 06:03 PM
  #89
try 19-20lbs and do a 10count for your burnout...
Old 04-17-2007, 01:34 PM
  #90
1BadZ95's Avatar
I tryed 20 the first run, cut a 2.1. I'm goin back tomorrow, so I'll try a few different things and post up. Could it be because I'm down past the wear bars?
Old 04-20-2007, 01:41 PM
  #91
1BadZ95's Avatar
Well ended up not goin. So no results, until next time!
Old 04-20-2007, 02:46 PM
  #92
Keenov's Avatar
Hoosier Drag radials worked for me
Old 04-20-2007, 05:18 PM
  #93
LS144's Avatar
Best results I ever got was a 1.7.......
I dropped them to 8lbs heated them up and rolled all the way past the staging lines back up and romped from there.
Oh btw I started cutting 1.50;s on mickeys!
Old 10-10-2007, 06:05 AM
  #94
ramairws6's Avatar
Wow.....hate to dig up an old post but couldn't resist.I ran 1.49 60 foots with Nittos at the track so to say they suck?You be the judge!?Traver
Old 10-10-2007, 08:51 AM
  #95
Ls1Bait's Avatar
Yea I cut 1.73 60' on my Nitto dragradials. Remember though if your bolt on suspention isnt dialed in (or if you dont have any) then that could be the problem not the tires. I have full bolt on suspention and after my sphon adj. touqe arm it changed my launch quite a bit. Changing that pinion angle is key to a good launch
Old 10-10-2007, 10:01 AM
  #96
98TADRIVER's Avatar
Originally Posted by Vic02BlackZ28
Well as the title says Nitto Drag Radial suck. I mean I knew not to expect great 60ft times from these tires but I would have thought it could have been a little better than street tires. Oh well....guess I'll have to wait for the 12.8 time slip. Anyway here are my time from tonight at the track. Look at the RT on the 3rd pass! OH YEAH! 8)
1st pass
60ft - 2.133
330 - 5.699
1/8 - 8.542
MPH - 87.53
1000 - 10.980
1/4 - 13.05
MPH - 108.90
2nd pass
60ft - 2.120
330 - 5.663
1/8 - 8.485
MPH - 88.08
1000 - 10.908
1/4 - 12.969
MPH - 109.48
3rd pass
RT - 008
60ft - 2.104
330 - 5.650
1/8 - 8.474
MPH - 88.16
1000 - 10.896
1/4 - 12.956
MPH - 109.58
before i flame you on your driving, is this an A4 or M6? i didnt take the time to read thru 7-8 pages here, so im just going to say, if you are an M6 guy, you need to learn how to launch her a lil better! alot of people just rev it up and dump the clutch thinking theyll take off. only thing they will do is spin or bog. i got my 98 t/a into the 12s with a lid, catback and free mods. i ran a 12.97 @ 110mph then in the spring i had longtubes and an ory, and was running 12.70s @ 111mph with 1.88-1.90 60's on street tires again, then It killed the 10bolt.
My nittos kicked *** on the street for what they were, i could launch it at 3200-3500rpm on the street and hook
Old 10-10-2007, 08:51 PM
  #97
its turbo time's Avatar
if he's not hooking at 15 psi would adding air help him?
i've only had two runs on the nittos and the stall and my best was a 1.8 with 13 psi and probably a 5 count burnout, and i spun pretty good.
Old 10-10-2007, 10:27 PM
  #98
rel3rd's Avatar
My N/A A4 car has bone stock 112,000 mile suspension and with 275/40/17 Nittos has cut 1.76-1.77 60 foots almost every time so far. Whether they are aired up to 30psi, or let down to 21psi, it makes no difference.
Old 10-10-2007, 10:46 PM
  #99
This time was along time ago... I ran that combo for ever 31517 nittos. On the 10bolt with a 3500stall i was hooking a 1.5 with a lil spin on motor it would do a high 1.5 slightly stalled and for somer reason nittos like to be around 19-20lbs for the track and daily use imo thats where i keep my new 315/17 mickey thompson et street radials.
Quick Reply: Nitto Drag Radials SUCK!
