12 Second Club In the 12s yet? Come inside!
Disappointed, 12.611 @ 109.58
Old Jun 6, 2008 | 03:05 PM
tkimrey's Avatar
i've been thinking the same thing here lately, although it runs great on the street. My buddy has an old fox body stang that runs 12.10-12.20's and every time i run him on the street i put at least two cars on him, but i couldn't run better than what i did at the track
Old Jun 6, 2008 | 05:42 PM
Merciless's Avatar
Originally Posted by tkimrey
it's the torquer v3. specs are 231/234 .644/.598 111 lsa
yeah i was asking the same question about the torque.
That is a monster cam. I'm assuming you upgraded the valvetrain to support that???
Old Jun 6, 2008 | 05:46 PM
tkimrey's Avatar
lol,it's in the sig and yes i did, i don't think my car would be running if i didn't upgrade the valvetrain
Old Jun 6, 2008 | 06:06 PM
Merciless's Avatar
Sorry dude it just seems like something is broken to me, only reason I asked. How about your coil packs? Are you getting a nice spark???
Old Jun 6, 2008 | 09:20 PM
Paint_It_Black's Avatar
It's your stall. I don't want to go into detail, for fear of a flame war. I recommend a Yank PT 4400. I bet you gain 3-4 mph and run .3 faster. (ok, maybe I'm just a Yank fan)
But also, what was your 1/8th mile mph? If you're falling down on the big end, your trans could just be toast.
Old Jun 7, 2008 | 05:43 AM
Merciless's Avatar
I'd be the first to jump on the Yank bandwagon with you, but a Fuddle 3500 should certainly produce better than a 12.6 with the other mods. 3rd gear being shot to **** would make sense though if his 1/8 mph is right.
Old Jun 7, 2008 | 10:56 AM
tkimrey's Avatar
the 1/8 mile times were 8.092 @ 86.67 mph and i'm still running on the stock
4l60e (which i hate btw)
as far as i can tell spark is fine.
Old Jun 7, 2008 | 11:35 AM
Jordan S.'s Avatar
The biggest thing holding you back is your tires. You need some slicks or good drag radials.
Old Jun 7, 2008 | 03:23 PM
I always thought you should be gaining about 30mph from the 1/8th to the 1/4. You're gaining 23. There might be some slip in there somewhere. I wonder if any other stalled autos can post their 1/8 to 1/4 mph gain
Old Jun 7, 2008 | 03:37 PM
quadd2244's Avatar
Just for comparision sake my bolt on trans am with a 3000 stall is VERY close to the times your running and our 60fts are the same. Id say you definetly have something wrong
quadd2244's Avatar
oh and I am still on the stock ls1 intake manifold and stock heads/cam
Old Jun 7, 2008 | 04:13 PM
  #32
tkimrey's Avatar
you may be right about the converter, i was driving it a little today and when it starts to lockup it feels like its slipping, so that might be a problem and the fact that i'm still on the stock tranny
Old Jun 7, 2008 | 04:25 PM
  #33
rsodeputy61's Avatar
something's def. wrong...you should be close to or at 400rwhp with that cam/setup. let us know what u find...good luck!
Old Jun 8, 2008 | 07:53 PM
  #34
s346k's Avatar
you should pick up 22-24 mph from the 1/8 to 1/4. 30 is a BIG stretch, this isn't a pro mod turbo car going 4s in the 1/8. i had a fuddle converter in my car, i doubt that is the problem. a slipping trans would be evident under wot - you'd be banging the rev limiter all the time.
Old Jun 8, 2008 | 09:55 PM
  #35
tkimrey's Avatar
i do hit the rev limiter but only on the 2-3 shift, i'm calling up the tuner tomorrow and see if we can fix that little problem and also see if there are any other problems. might see if we can't change a couple of things as well.
Old Jun 9, 2008 | 10:23 PM
  #36
01ssreda4's Avatar
pm hilton. he has a V3 and he runs a good 11 something at like 120 something. thats with a bfg DR.
Old Jun 10, 2008 | 07:26 PM
  #37
tkimrey's Avatar
thanks, i'll see what he has to say about the subject.
Old Jun 15, 2008 | 09:08 PM
  #38
tkimrey's Avatar
Ok, well I took my car to one of my buddies and he put it on his tech2 and we found out that my o2 sensor heat circuits were in the dump, so I guess that would explain why my car is running like crap. I'm going to replace the o2 sensors and call my tuner up and see what he thinks. Then I'll be making my way back to the track to see if that helped any.
Old Jun 15, 2008 | 11:18 PM
  #39
TedsB4Csled's Avatar
not sure if you can see this but it's my last dyno that i had.
If you can't see it it says: Run conditions: 66.08 degrees, 28.85 in-Hg, STD: 1.03
Max power = 353.19 Max torque = 319.10
That torque is AWFUL! Somethings gotta be wrong there. How did tuner explain that???
Old Jun 16, 2008 | 08:48 AM
  #40
tkimrey's Avatar
Lol, well he didn't explain it, he just said take it to the track and see what it runs...
