Easiest 12.5
Jon
I had to launch at 1000 rpms then roll into the gas to stop from spinning. When i get drag radials i believe i can hit a 12.7 with my set up and hopfully a 12.5 with gears.
LCAs and SFCs might not make much difference, but a TA will help you 60 better. My car, which doesn't spin and only has a few bolt ons, cut a better 60' with an aftermarket TA. It previously had bests of 1.950 and 1.960 out of about 30 passes. With the addition of a TA, it's made a 1.919 and 1.932, The DA for those passes is about 600' less but it also had an extra 200lbs in the car.
Not much of a gain, but I'm only running 12.9s and like I said the car doesn't try to spin the regular radials at the track. If I were to the point where I needed a better tire I'm sure it would make much more of a difference
I was running 12.3's with bolt ons and you were running 12.9's. I'm NOT saying you were stupid. Different strokes for different folks. But I am pointing out how bad your argument is that I am stupid
I don't think he was talking about me. But I'm sure you knew that being so smart and all
I understand that you are saying buy the stall before the TA, I found a deal so I went ahead and bought it. I had the LCAs and SFCs from my old LT1 car. If I could get a stall that cheap I would have it already as well. AND the OP already has a stall, he needs tires and suspension.
Jon
$700 for a new Circle-D converter is a bargain IMO. I would definately save up and make that the next mod. Besides the kick *** track times, the car is way more fun to drive.
His stall is a little on the small side. But his sig says he has 3.42's and drag radials coming soon. So IMO his next mod money would be best invested in LT headers and an ORY to complete his free flowing exhaust.
LT's, 3.42's and drag radials should be enough to get him mid 12's right now. Then after that I might consider suspension and upping the stall size to the 3600-4000 range
It is a daily driver so the highest i think i would want to go is 3200-3600 stall. I would like to get headers but I am going to have to get a catted y-pipe cause my girlfriend will yell at me about the enviroment if i don't. So I was thinking my next mod after the gears and tires would be 100 shot then i can drive a ~12.5 second car on the street and a ~11.5 second car at the track.
You'll probably keep the car longer then the girl so just get the ORY
J/K
Dynatech makes a nice stainless steel LT header setup with a high flow catted Y-pipe.
Good luck!
i dn what other people think but... running low 12's with bolt ons and full weight is pretty much impossible... i almost have ful bolt ons and i weigh in at 3340lbs and i only run mid to high 12's to run low 12's bolt on only it will require a moderate amount of weight reduction...
I ran 12.4's @ 109 with my car full weight and that was without a lS6 intake, UD pulley, gears and an efficient converter (I was running a TCI 3500 where I'm sure a Yank SS4000 would have gotten better ET's).
Jon
