12 Second Club In the 12s yet? Come inside!
Can i make it????
Old Aug 4, 2008 | 11:41 PM
Z28SteveA4's Avatar
Default Can i make it????
I am hoping that i will break 12's this week if i can make it to the track. I have a 98 camaro. My set up is slp headers with slp catted y pipe with a borla cat back. The headers are not the slp tuned header. I have the slp lid and spohn lower control arms and pan hard bar. I also have a umi k member not like its going to make that much of a differance. My tires are brand new bf goodrich gforce super sports. If i heat the tires up enough and get traction i'm hoping to be in the twelves. My gears are 3.23's too. I know heating up new tires but life goes on! Sorry if threads have been posted like this before and i'm creating another one but idk if i should give up hopes for twelves without a converter and tune.
Old Aug 5, 2008 | 01:33 AM
jetlag's Avatar
Yes, look at my times in signature...
Old Aug 5, 2008 | 03:57 AM
95 Z28's Avatar
I think you'll get it. Those tires are regular street radials, correct? If so, I wouldn't try heating them up too much. When I used to run on street tires and did a nasty burnout they'd get slipperier. A simple quick burnout to clean them off nice should be more than sufficient.
Since you're in NJ, close to sea level, I say go on a day with good racing weather and it shouldn't be a problem. Good luck.
Old Aug 5, 2008 | 08:14 AM
Z28SteveA4's Avatar
thats a dam good time for your mods but i can't see myslef getting that but i can hope!
Old Aug 5, 2008 | 08:17 AM
Z28SteveA4's Avatar
thy are the only gforce that is an all season tire so i'm not sure if they still consider it a street radial but they should hock with a small burn out. thanks man. i'll let everone know what i run when i go.
Old Aug 7, 2008 | 01:07 PM
nmelone21's Avatar
you know if you hit 12s..ill be your witness.get this car done for friday kid!
