A wierd oil pressure issue?
Just letting you know i fixed the oil pressure problem.I installed the canton pan and pickup and i set it as close as could, at 1/4 clearance clay measured. This was using the pan gasket during mock up. That was the closest recommended clearance in the instructions. I did not use that tab that bolts to the pump as that made my clearance was too much. But i did weld the pickup on and use the Gm high pressure white spring. Now it holds 75-80psi solid to 7k also using 20-50wt vr1 oil.
