Advanced Engineering Tech For the more hardcore LS1TECH residents
diagnose the misfire
Old Nov 12, 2008 | 05:31 PM
supersix's Avatar
Default diagnose the misfire
I have 2 2000 TAs, one manual, one A4.
Manual Car cylinder #7 misfire under load. Changed: Plugs, Wires, Coil Pack, Injector, Traced wire back to ECU, Replaced ECU.
A4 cylinder #3 misfire under load. Changed Changed: Plugs, Wires, Coil Pack, Injector.
Anything I am missing (no pun intended)?
Old Nov 12, 2008 | 11:12 PM
Todd157k's Avatar
what plugs you using? other engine mods?
Old Nov 13, 2008 | 09:21 AM
supersix's Avatar
a4: Stock cube rebearinged engine, 238/242 .605/.610 113+4, Stock 2000 heads, Dual Valve Springs, hardened push rods, Weiand intake (boat anchor), Stock Throttle Body, and stock injectors.
Old Nov 13, 2008 | 11:11 AM
supersix's Avatar
Found it.....Intake leak....next time don't install weiand intake for customer.
