superchrged + twin turbos ????
i'd like to know the cost break down between vnt warranty repairs vs. increased manufacturing costs and complexity of the compound turbo/super charger setups.
The 3rd gen RX-7 uses two turbos but they are diff sizes and the computer switches the smaller turbo off as the motor rises to a larger turbo to help prevent the torque of the rotary being so low.
All of our Titan crash fire trucks on post use the compound roots/turbo system and they are very reliable.
unless the guy figured he needed the turbo's to make up for the parasitic power loss caused by the supercharger, and then decided he needed nitrous to help the turbos spool faster
hmm eliminates turbo lag?? i dont think so... it reduces it, yes, but for example the new duramax has a VNT... and still is over 3 seconds of lag from a standing start.
Superchargers and turbochargers still are orders of magnitude different in response time, VNT or not...
VNT's are expensive and are much more prone to breaking.. The technology is great, but with complexity comes cost and with 'complexity and high temperatures' comes reliability issues... The technolgy is great but its definately not the "end all, be all" of boosting..
my experience with vnt was the shelby daytonas with vnt. and those thing came up on boost instantly, there wasnt any perceivable lag time.
but ya, they were prone to breaking ... alot ...
Basically, a roots-style blower can only grab N/a air up to a certain rpm of efficiency. After that, it simply cannot pull more air because of its design. It is essentially a boost multiplier. (which is why an 03 cobra has so much torque, but a comparably weak high end, and why a centrifugal blower-style car will not have the guts in the low end, but will fly by in the high end-it takes time for the centrifugal to build boost, much like a turbo).
With a turbocharger and supercharger, the turbo is used to compress the air and force it into a roots-style blower so it can multiply the boost and achieve an incredibly high compression ratio. This is mainly used in diesel engines, like redta said, because they are compression-based engines.
sorry if the question was answered already, but I just read the first few posts
Chris.
Of course the twin kit made more power than the hellraiser at the same boost. The supercharger at this point would just act as a restriction. The power increases when the boost is compounded to high psi levels.
Chris.
be nice for someone to try all these ideas though.
Chris.
