Advanced Engineering Tech For the more hardcore LS1TECH residents
affects of short block sitting around
Old Jan 3, 2009 | 02:28 PM
THE LAST Z's Avatar
Default affects of short block sitting around
Say I orderd a freshly put together short block, but Its not installed for a while. How long can it sit around before things start to go wrong? How can you protect it from sitting around long term?
Old Jan 3, 2009 | 02:42 PM
Avaric3's Avatar
i would guess keep it well covered, protected and dry and you would be good a long time
Old Jan 3, 2009 | 03:08 PM
Dave88z's Avatar
I spray mine every month with WD-40 to keep surface rust from forming. I also rotate the crank a few times to make sure the cyl walls get coated.
Old Jan 3, 2009 | 06:48 PM
chevy2808's Avatar
i agree with dave88z...wd-40 that bad boy, keep it extremly clean and dry, and rotate it every so often to keep it in good shape
Old Jan 3, 2009 | 06:58 PM
CTSmechanic's Avatar
Use Caution in what type of oil you use.... The cylinder walls and rings might get pissed....
Old Jan 4, 2009 | 09:11 AM
Dave88z's Avatar
Is WD-40 good or bad? What oils should not be used?
Off topic but CTS are you a mechanic? I am a mechanic, and my wife and I are looking to move to the Charlotte area. I am wondering what a good mechanics salary is down there. Shoot me a PM if you have time.
Old Jan 4, 2009 | 11:41 AM
THE LAST Z's Avatar
What about just regular oil?
Old Jan 4, 2009 | 08:41 PM
GIGAPUNK's Avatar
Don't use wd40! It's half solvent. If you want proof spray the **** out of a wrench and and leave it on your work bench for two days... It'll be dry.
Old Jan 4, 2009 | 09:12 PM
LS6 Silverado's Avatar
Marine fogging oil. Good stuff, puts a nice film of oil on cylinder walls that hangs out a long time. Spray it, rotate to coat cylinder walls, spray again and cover up. Good for quite a while. Probably not a bad idea to hit lifter bores etc as well.
Old Jan 4, 2009 | 09:23 PM
F3RR3T's Avatar
lmao yankee bullstuff that info is
Old Jan 4, 2009 | 10:14 PM
GIGAPUNK's Avatar
Try it.
Old Jan 5, 2009 | 07:00 AM
F3RR3T's Avatar
Try it.
i have been for about 3 years. as well as my father for about 35+
Old Jan 5, 2009 | 07:26 AM
GIGAPUNK's Avatar
I meant the work bench test. There's better ways to protect a block.
Old Jan 7, 2009 | 07:44 PM
Black02SLPSS's Avatar
linseed oil works well too
