any fellow techs on here today?
Have you probed with the right connectors to see if you are getting a constant 12v or a constant 5v every system is different. If you do see if you ground is good. Do a OHMs check on the ground wire, then if that is good see if the referance wire is good with and getting a siganl you can probe the signal to the grond on the same contector and see if you are getting a good signal. I would start there and get back with what you find.
