Advanced Engineering Tech For the more hardcore LS1TECH residents
Whats the difference with more or less lifter preload?
Old Jun 21, 2009 | 10:40 PM
BigRich954RR's Avatar
Default Whats the difference with more or less lifter preload?
OK im running morrel lifters. Thinking specs are .030-.050 preload ?
Lets say engine is set at .025-.030 will it be pumping less oil to top of engine?
Whats the affect of have more preload or less preload on a lifter?
Old Jun 22, 2009 | 10:41 AM
3.4camaro's Avatar
I think preload is less about oil pumping and more about keeping parts of the valvetrain in contact with each other. Too little preload and your pushrods will start bouncing off of your lifters, resulting in valve float or perhaps something worse.
Too much preload will not let the lifter fully pump up, and may damage the lifter, cam, or pushrods.
If I'm full of ****, someone please jump in here and correct me.
Old Jun 23, 2009 | 03:04 PM
Wesmanw02's Avatar
Preload is basically a happy medium.
You want to keep a constant pressure on the lifter, without bottoming it out. This takes up any lash in the valvetrain.
As long as the preload is within spec, it shouldn't affect oil flow to the top end of the engine.
Old Jun 27, 2009 | 08:23 PM
Sharpe's Avatar
"Preload" is something I know next to nothing about. I wonder if some cam gurus can come in here and tell us idiots a little about it in general, etc...
Old Jun 30, 2009 | 12:56 AM
Nitroused383's Avatar
Good info here:
http://www.hardcorels1.com/vbulletin...ead.php?t=1815
http://www.hardcorels1.com/vbulletin...ead.php?t=2938
Old Jun 30, 2009 | 10:52 AM
JUNK's Avatar
Every engine builder has his own preference, but in my experience w/ hyd. rollers, slightly less pre-load = more usable rpm and louder valvetrain. More pre-load = less off-idle torque and 100 or more less rpm on the top-end. This would be agressive ramp-rate cams in the 230*-up area, and if u have a lot of overlap, looser helps the idle. You can definetly hear mine if that tells you anything about my thoughts.
Old Jul 13, 2009 | 07:00 PM
JPH's Avatar
JPH
Depends on Who's lifters also.
Old Jul 25, 2009 | 07:33 PM
lovescamaros28's Avatar
No,pretty much right on the money.
Old Aug 15, 2011 | 01:48 AM
red 454's Avatar
what do think about this
http://speedtalk.com/forum/viewtopic.php?t=1562
http://www.cranecams.com.au/pdfs/pp1110c.pdf
Old Aug 16, 2011 | 10:07 AM
87gnx's Avatar
Since you have the spec, I'd set them at .040 and call it good. $.02
Old Sep 21, 2011 | 01:22 PM
1lejohn's Avatar
It's more critical for soild roller cams then hyd. If your are not careful you may collaspe the hyd lifter and make it act like a soild.
