Advanced Engineering Tech For the more hardcore LS1TECH residents
Piston Rock at TDC
Old Jun 24, 2009 | 01:29 PM
the_merv's Avatar
Veteran: Air Force
Default Piston Rock at TDC
How much Piston Rock should there be at TDC?
I have a 6.0l Block, 4.000" Bore with Eagle 4.000" Crank & 6.125" Rods. I just pulled the Heads cause I have bad Rings, I'm wanting to make sure that I don't have excessive Piston Rock.
Old Jun 24, 2009 | 02:33 PM
DeltaT's Avatar
You'd have to measure the pistons and actual bore and then compare your numbers to the piston mfg's suggested fitment numbers for clearance. I always think that my piston rocks too much even when the clearance is set dead nuts on.
Jim
Old Jun 24, 2009 | 05:53 PM
the_merv's Avatar
Veteran: Air Force
I got a measurement on the Bores of a 4.003"-4.004"..so that may be a good reason for my problems..
Old Jul 14, 2009 | 11:56 PM
MAC4264's Avatar
What brand piston. Look at some of my old threads.
Old Jul 15, 2009 | 08:29 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
The crown of most forged pistons is roughly .055" smaller (when cold) than the diameter at the piston skirt. This is intentionally machined by piston companies due to the top of the piston being in the line of fire and absorbing direct combustion heat. As the engine is warmed up this clearance tightens up significantly, and when running warm has very little piston to bore clearance. I don't think you could take it apart quickly enough to measure the actual running clearances though.
Unless the piston rocks 1/4" or more, cold-piston rock tells very little about what the clearances are.
Old Jul 15, 2009 | 11:39 AM
racer7088's Avatar
Arrow
Stock pistons cold rock about .020 ish as in if one side is pushed sideways it may go .010 out of the hole and then .010 in the hole when rocked the other way. Forged pistons have generally more rock when cold. Some of the wiseco and Diamond LS1 specific stuff is still only like .020-.025 where as some traditional forgings and skirts can be much more like .030-.040 even so it all depends. When hot these all rock much less.
Old Jul 15, 2009 | 11:40 AM
racer7088's Avatar
Arrow
The bores will wear more at the top of course over many miles since the rings have the most pressure and load on them around TDC.
Old Jul 30, 2009 | 08:39 PM
lovescamaros28's Avatar
Jim
You can also check piston to wall clearance with a ribbon feeler guage.I agree it is more accurate with a dial bore guage though.
