What is my compression ratio (static)?
How much "down in the hole" is the piston at TDC, and how much volume would that displace? Lets call this Vdh.
Also, I need the volume of the head gasket. Lets call this Vhg. I do not recall the thickness.
So far I have:
CR = [825 + 10 + 64] / [10 + 64] = 12.15 which is way to high.
However, I need the following:
CR = [825 + 10 + 64 + Vdh + Vhg] / [10 + 64 + Vdh + Vhg] to accurately calculate the static compression ratio.
KCS: I believe that you have given me the missing volumes. Thank you.
