new Ohms Law(lol)
The last time I checked. I=E/R If voltage goes up and resistance stays the same amperage goes up.
In a parallel circuit, the current drops/divides and the voltage stays the same. The current equals the current supplied.
See this: http://www.hvacwebtech.com/Ohm's%20Law.htm
Talking about AC powerline transmission, that is a different thing or even an AC circuit for that matter. The voltage is inversely proportional to current. Like a transformer for instance.
Step up voltage transformer: step down current.
Step up down transformer: step up current.
http://www.hobbyprojects.com/ri_in_A...C_circuit.html
Like said in that link, the voltage has to be RMS or peak.
From Summit, SUM-820323 12v DC 1.9hp. Other specs not stated. We all know that starting current can, depending on conditions, be well over 100 amps.
Also note that this motor would be fed with a #4 or #6 cable to accomodate those conditions. Duty cycle is maybe 10%.
To feed the Grainger motor, all that would be needed is #12 wire to keep it happy at full load, 100% duty cycle.
I'll note that the differences here are .1 horsepower. Both are DC motors. As the supply voltage went up, the current requirement went down.
You see the same differences in AC circuits, depending on what you are trying to accomplish. Look at the current requirement differences between equivalent cooling capacity 110v and 220v air conditioners.
Go back to the link I posted previously, and go to the bottom of the page to see ALL the permutations of Ohm's Law.
