Advanced Engineering Tech For the more hardcore LS1TECH residents
Cylinder Honing
Old Aug 24, 2009 | 09:06 PM
Petraszewsky's Avatar
Maybe I'll try some WD40 to take it off rather than using the hone again and making another mess...then having to clean the block meticulously once more...But before I washed the block with the soapy water each time I went clockwise and counterclockwise with the hone I wiped it before the next pass with mineral spirits and it didn't rust...And once more thanks for your replies...
Old Aug 25, 2009 | 02:09 PM
While I was cleaning the block yesterday I noticed this crack...It's on the passenger side down by where the A/C compressor would mount...How concerned should i be about it?
Attached Thumbnails Cylinder Honing-img_4029.jpg   Cylinder Honing-img_4035.jpg
Old Aug 25, 2009 | 04:39 PM
racer7088's Avatar
You could have it welded or fused back together but just don't really overtighten that bolt as that's how it cracked probably already
Old Aug 25, 2009 | 05:08 PM
I won't even be using those bolt holes anyways...I've got the high mount A/C kit from Kwik Performance...So it should be good to go? It won't open up into a huge crack like a black hole?? haha
I just checked my main bearing clearances and they are pretty much around .0015 or a lil larger..maybe something like
.0018 is this too tight...it should be fine with using 5W-30 oil right...Although the book I have recommends .0021-.003...
Old Aug 25, 2009 | 07:45 PM
racer7088's Avatar
Personally I would open the clearance up a lil bit then to around .0020-.0023 but it would be in stock range. I like stuff to be pretty safe even cold so we run a little more clearance.
Old Aug 25, 2009 | 10:15 PM
I read a few different articles that discussed the .0015 clearance and it may be a bit tight but I think it'll do for this build...I don't want to come off like I'm just throwing this thing together...Or that I am satisfied with mediocre
workmanship though...I want it to be a nice reliable engine but I want to put it together myself if you know what I mean...I learn better by doing it myself and I don't know anyone personally that has put a engine together..(other than friends/family back home..But I'm stationed down here in Savannah GA.) Rod clearances are fine and I got the crankshaft/main caps installed today too..Shortblock will be complete tomorrow!!! I dunno when I'll get to crank this sucker up but let's cross our fingers that it doesn't fall apart!!! haha..
Would you think that Total Seal's "Quickseat" would help benefit at all?
Old Aug 26, 2009 | 03:24 PM
racer7088's Avatar
Don't really know on the quickseat stuff on that deal. You could ask them but they would probably you had a truely honed cylinder as well!
Old Aug 26, 2009 | 03:33 PM
Don't really know on the quickseet stuff on that deal. You could ask them but they would probably you had a truely honed cylinder as well!
Did you mean to say if I had a truely honed cylinder as well?
I guess there are pros and cons to "soft honing"
Old Aug 26, 2009 | 06:08 PM
racer7088's Avatar
Not too many pros but you can ask them. It should still get by for you.
Old Aug 26, 2009 | 09:52 PM
After finally assembly even though the rings haven't been seated and the engine never been fired...could I still perform a leak down test to get a idea of how well it's sealing? Or does the engine have to of been broken in to get a proper reading?
Old Aug 26, 2009 | 11:08 PM
racer7088's Avatar
After finally assembly if though the rings haven't been seated and the engine never been fired...could I still perform a leak down test to get a idea of how well it's sealing? Or does the engine have to of been broken in to get a proper reading?
You can but it will improve a little after running usually.
Old Aug 27, 2009 | 12:02 AM
  #32
I'll try it after I finish putting it together and see what I come up with...Then I could have some numbers to compare to after I finally do get to break it in...
