Advanced Engineering Tech For the more hardcore LS1TECH residents
6.0L Iron Block in CTS-V
Old Oct 1, 2009 | 08:50 AM
MastaAce98's Avatar
Default 6.0L Iron Block in CTS-V
I'm not sure if this is the right forum for this question, but I have a CTS-V that I'm putting a 6.0L block into right now. I got a call yesterday that the mounting plates that the engine mount would go into is different between the LS6 block and the LQ4/9 iron block. Does anybody know what's different and what do I need to do to fix it?
I came across these online, but I've never heard of the shop before:
http://www.trentfabrication.com/stor...roducts_id=297
Any help is appreciated. Thanks!
Old Oct 1, 2009 | 09:10 AM
SkullV's Avatar
Those are mounts to put an LSx motor into a Jeep. Not sure how that would help your application.
Old Oct 1, 2009 | 09:12 AM
MastaAce98's Avatar
I wasn't sure, that's why I asked. But either way, I'm trying to find some info on getting that 6.0L block in there, and the only answer I seem to be getting is that I have to fab something, but I can't imagine why they would be different.
Old Oct 1, 2009 | 12:54 PM
one fast zo6's Avatar
iron block will work great.
Old Oct 1, 2009 | 01:18 PM
MastaAce98's Avatar
I know, my D1SC is so ready for it
But apparently the stupid motor mounts are different. I talked to the guys at LMR, they're just going to fab something up - I just didn't want to if I didn't have to....
Old Oct 1, 2009 | 11:27 PM
MelScrilla's Avatar
I thought the mounts on all LS motors were in the same place?
Old Oct 1, 2009 | 11:29 PM
MastaAce98's Avatar
I thought they were too dude, but they're not. Check this out....
http://www.cadillacforums.com/forums...or-mounts.html
Old Nov 27, 2009 | 10:25 AM
MIGHTYMOUSE's Avatar
oh please.. the blocks are the same.
Old Nov 27, 2009 | 12:42 PM
2c5s's Avatar
The blocks are not the same. Check my old posts, I had my guy fab up the stock motor mounts for my iron block in my V.
Old Nov 27, 2009 | 03:50 PM
KCS's Avatar
KCS
Moderator
WTF? How are the blocks different?
Old Nov 27, 2009 | 04:29 PM
2c5s's Avatar
The rear mounting pads on the block are not there.
Old Nov 27, 2009 | 08:15 PM
KCS's Avatar
KCS
Moderator
Rear mounting pads? On the block?
Old Nov 27, 2009 | 10:38 PM
elias_799's Avatar
all Ls series motors have holes in the block for the motor mounts in the exact same spot.
Old Nov 27, 2009 | 10:48 PM
2c5s's Avatar
Then maybe you can explain why both iron 6L blocks I installed in CTSV's required modified motor mounts to allow them to be mounted in the cars?????
As was stated before, the rear mounting pads are not on some iron blocks.
Old Nov 27, 2009 | 11:30 PM
elias_799's Avatar
rear mounting pads ? all the ls motors i have seen are mounted with a clam shell on each side. atleast all the one's i have seen. i never worked on a cts-v so i can't really understand the problem
Old Nov 28, 2009 | 09:18 AM
2c5s's Avatar
Generally LS blocks have 3 mounting pads on each side. Front middle and rear. GTO, CTSV etc use the front and rear pads for their motor mount. C5's use the front and middle pads. The iron 6L blocks I've used only have the front and middle pads cast into the block, which requires a modified motor mount.
