Advanced Engineering Tech For the more hardcore LS1TECH residents
ignition coil with or without amplifier
Old Oct 14, 2009 | 04:48 PM
jeejee's Avatar
Default ignition coil with or without amplifier
How can i find out if a coil has a build in driver / ignitor ?
This is not specifically Ls engine related..
The reason i ask is, i have a aftermarket ecu and this can only fire coils with internal driver, If i would use a coil without one, i would blow the ecu.
this is the coil in question , it has 3 connections..
thanks, Jeejee
Old Oct 18, 2009 | 12:41 PM
jeejee's Avatar
Well, where are all the tech "guru's" ?
Old Oct 19, 2009 | 10:26 AM
jimmyblue's Avatar
Moderator
A coil with no built-in electronics only needs IGN,
switch and plug. That's a 2-pin connector. But I
would want to go to the donor vehicle's shop manual
to make the call.
