C5R Experts only...tough questions.
First, when was the first engine (working prototype?) built? I know Schwartz (?spelling) built the blocks and even the C5R heads but they did not (I asked them) finish the heads. Who did? Katech says it's not them. Who prepared the heads for final use?
The piston? When and who built and/or designed the first ones? Diamond? JE? Maybe Schwartz again?? And is there a difference in the C5R 427 piston and any other GM 4.125" piston? In other words would the piston you would put in a sleeved LSx engine be the same or would the C5R not clear the reluctor ring or whatever? How much difference between the C5R piston and the LS7?
Who was the first piston builder to make them available and when? I think this was in '01 but not sure. Again, is there anything unique to the C5R piston that would make it applicable to only the C5R or is it still an off the shelf piece.
Any other historical facts of links would be appreciated. thanks
Several companies have machined the heads over the years. Reher Morrison, CFE, and a little bit by Katech. Katech did do one of the ports used in the race program, but not much.
The first pistons were JE. There is a build sheet for the pistons dated 10/21/97. How much is different from any other GM 4.125 piston? To put it simply, everything but the bore. Later pistons were made by Mahle.
My earliest memory of C5R blocks running on the streets were GMMG ZL1s and in fact someone here posted a video of the car, a yellow car owned by a guy named Barnhart (?) in 2002 I think. But, I've got to think the really big tuners and people like LPE and Katech had some street C5Rs out before that. Or for that matter probably some LS1.tech sponsors had them on the street by 2001. As a matter of fact I bought a pair of used C5R heads right here on LS1.tech in July or so 2002. These were used Katech heads, according to the guy I bought them from, and were set up for a solid roller.
I'm not positive on this one but isn't GM bringing the C5R block back? Seems like SDPC has them.
GM will never make the C5-R block again. The tooling is gone. SDPC is out of stock but they can get them from a GM warehouse which has plenty.
