Static Compression vs. Dynamic Compression Ratio
2.What is the target dynamic compression ratio that I should be "looking" for running 91 octane?
Thanks for your help, fellas...
If engine builders would tell you, ask them what pumping or cranking PSI they see with certain setups (heads, plugs, temps) may get you insight and direction... Then it is a matter of trail and errors with cams/ quench i suppose oh and I would love to see the results of testing
>.. i used this to figure it. just use 0 for boost. and you can look up your elevation on google.
http://www.empirenet.com/pkelley2/DynamicCR.html
the important thing to remember is that DCR just like SCR does not change with rpm, unless you have variable valve timing then DCR will change. Regardless of that, from the fuel's point of view it does not care what the compression ratios are, it cares what the cylinder pressure is because it's the cylinder pressure which creates the heat which causes the fuel to detonate, and cylinder pressure varies with rpm with max pressure happening at the rpm max torque occurs. So i would not solely focus on DCR.
I've read that cylinder pressures near 200 psi and above will cause 93 octane fuel to detonate, hence the ~180psi cranking compression which is what most street engines are. And other factors will influence the detonation point of the fuel... primarily combustion chamber design and piston to head (quench) clearance- the tighter the quench the better detonation resistance for a given octane allowing for higher cylinder pressures (or compression ratios), and the converse being true where if you lowered compression ratio to 9:1 versus greater than 10:1 but the engine would still knock and detonate because of too large a quench area.
http://kb-silvolite.com/calc.php?action=comp
Since I set it up for daily driving I didn't want to push it too much, and had worked with my machine shop and the few "peak" safe numbers we could find (8.5ish dcr) and backed off a little from there....the setup was actually very easy to drive on the street and with the 3" dual exhaust at 8,000 rpms it sounded like God was pissed off and coming after you
I've even had the thought of dropping two big turbos on it to kind of build in lag, so its not really building boost til just over 4,000 rpms (engine spinning too fast for detonation to occur) might even be able to hit the magic 1,000hp number then
I would have been tearing it back down to open up the chambers some to drop the compression back down if had found it was too high to run on pump gas lol and i would not have been happy.
But i must say, even with the huge cam it is very peppy even just off idle
lol
