Advanced Engineering Tech For the more hardcore LS1TECH residents
W8 vs. V8
Old Jul 19, 2010 | 11:29 AM
  #41
elias_799's Avatar
Originally Posted by nodrok
Veyron Impressive. But bugatti is stupid for manufacturing any car at a loss. If I remember correctly the areo broke the first record on a 3 mile run. Said that the car will do in the 260's range. Half the price, but half the options. Bugatti is very sexy and 5k pounds. To much money.
However, what about some kind of ls breed opposed 8. Porche, subaru, and the airplane industry has used them for years. They have proved to be very reliable. To me it just makes sense to have the combustion force driving towards each other to help absorb stress on the block. (but maybe it just makes more stress on the crank). They dont turn a lot of rpms but if you have enough power you can gear it however you want. I would also thing you could have a lower center of gravity for road racing cars. What do you think?
the gt3rs porsche engine turns to 8300rpm i think
Old Aug 5, 2010 | 09:03 AM
  #42
nodrok's Avatar
Porche is also a 6 not an 8. RPM is really irrelevant for most street applications. As long as you can make power and gear it right you can go fast. Look at the diesel guys. If your on the race track rpm is a different story. Its hard to say if the opposed engine is really any better than the current lsx engines as far as reliability. I have thought about it hard and the traditional V engine design puts a lot of stress on the mains while the opposed engine puts it more on the crank. I dont know if porches have any crank problem when really sticking the juice to it, but I would guess they would. Just my .02
Old Aug 5, 2010 | 12:26 PM
  #43
WSsick's Avatar
Normal Veyron- ~4500lbs (can you say normal Veyron? )
Veyron SS- ~4400lbs
Heavy, yes, but just a few hundred lbs off of the SRT8s
Originally Posted by mikelb51bk
Bugatti ss is stupid looking though
Stupid comment. Looks are subjective.
Old Aug 5, 2010 | 02:41 PM
  #44
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Isnt this the advanced tech section, all I see are opinions about the cars looks and google searches on records with no actual hard data comparing cylinder head flow, longevity or anything else.
Old Aug 9, 2010 | 10:44 PM
  #45
ZV8's Avatar
ZV8
Originally Posted by 06 6.0 GTO
Good call on already pointing out that the Bugatti super sport already took back the record, and yes it did haves less power and more weight then the Aero while doing it.
A lot of posts here are pure opinion.
Yea exactly since the maker of the Aero said the car wasnt toped out, just ran out of room on a PUBLIC ROAD!(it was closed to public obviously though) but still a bumpy public road is not the best place to test something like that and he said it could easily hit 270+mph if they were givin a test track like that one the Veyron SS ran on.
Further more, you guys saying the veyron will last 100,000km are clueless, you could have built 10 more 1000+hp LS motors for the price of JUST maintanence to the veyron. VW doesnt know how to make high HP cars, thats why the bugatti is so heavily dependandt on strong high tech expensive materials to make up for the lack of design. years of RnD and countless millions over a long period of time is how GM can do it easily now. You can go buy a 800+ci BBC that makes 2000hp N/A for under $100k and it will last longer than that bugatti. Hell you could buy GM's 572 crate motor and throw a turbo/supercharger on it with very low boost and make over 1000hp and it will last longer.
Old Aug 9, 2010 | 11:03 PM
  #46
z_speedfreak's Avatar
x2, I was hoping to see allot of hard facts and technical comparisons..
Old Aug 9, 2010 | 11:26 PM
  #47
shane2390's Avatar
my friends got one, they sound pretty crazy
Old Aug 10, 2010 | 01:27 AM
  #48
KILLER-LS1's Avatar
Photo of an actual Veyron engine block. This was at the PRI show (performance racing industry) in orlando last year
Old Aug 11, 2010 | 02:42 AM
  #49
chuntington101's Avatar
No one is argueing with you that the Bugatti is over priced and that a GM engine couldn't make that power and a lot more. But its clear that you just dont get the Veyron or any type of car like it! Sorry but if the Veyron used a GM engine (and they NEVER would!!!!) it would not be the car it is.
This is nothing against GM orny engine they make. Kornegsega (whatever the name was) made it very clear to the public that they only used a ford V8 race blok in their engine and that it sheard NO other components with the Ford engine!!!! the only hyper car company to use another companies engine is Maclaren with the F1 (and that was a massively worked BMW RACE V12) and Pagani with the Zonda's V12, and again that is had alot of work done to it!
Chris.
Old Aug 11, 2010 | 08:11 PM
  #50
OKcruising's Avatar
Originally Posted by elias_799
making 1000hp on 16 cylinders will always be more reliable then 1000hp on 8 cylinders considering both motor are made properly
Sure if your looking at the power per cylinder, but that's implying that the cylinder sizes between the two engines are the same displacement. Thus, it's highly displacement dependent.
But damn that Veyron block is BEEFY
Old Aug 11, 2010 | 09:19 PM
  #51
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I stayed away from here for a couple of months and came back to see posts about hydrogen generators, 100mpg carbuerators, and people who think you can atomize fuel enough to prevent detonation.
Old Aug 11, 2010 | 11:03 PM
  #52
abbaskhan's Avatar
buy this
http://nelsonracingengines.com/price..._454lsx_tt.pdf
and put it in this
http://img.dailymail.co.uk/i/pix/200...rL_468x582.jpg
Old Aug 14, 2010 | 09:41 PM
  #53
ND400's Avatar
From personal experience i can honestly say these engines are an absolute pig and there is still not enough to make them a reliable worthwhile engine. How long has the W8 been around 8 years? the V8...108 years...although many changes.
These volksys have a bit of a hunger for head gaskets, costly and engine removal makes your life much easier.
IMO steer clear, the Veyron is a supercar that costs around 5million USD to build then VW sell it as a loss because they want it to be the greatest automobile experiment ever.
So you cant really compare that to what we use, concept vs mass production. That just doesnt make sense does it
Old Aug 15, 2010 | 09:00 AM
  #54
7998's Avatar
I think the W8 is a complicated answer looking for a question. The W8 was used in the Passat and the Audi A6 which are both B5 platforms.
Audi had already put their 4.2l V8 in a B5.
I worked for VW/Audi during the time they were talking and developing the W8 and the Phaeton both of which were flops.
The W8 was made by lopping 2 cylinders off the15* narrow angle VR6 making it a VR4. Then they mated 2 VR4 blocks together to make a W8, 2 VR6's= W12 etc. The W family of engines isn't really ground breaking it is just a complex design for the sake of being complex. Audi's 5v per cyl is the same way.
Here is the inspiration for the Bugatti super exotic wunder motern
http://www.6066gmcguy.org/TwinSix.htm
http://www.youtube.com/watch?v=puJaDfB4UFM
Me too
Old Aug 15, 2010 | 11:46 AM
  #55
fleetmgr's Avatar
I'll take a blown and turboed V-16 71 any day. A pair will push a pilot rescue boat through heavy surf at 70 knots, and last 10k hours.
Old Aug 15, 2010 | 10:12 PM
  #56
Nebulus's Avatar
I know it's anti-creative thinking, but there's probably a reason why there aren't a whole lot of W8's floating around.
Old Aug 16, 2010 | 03:34 AM
  #57
Cheatin' Chad's Avatar
making reliable 1000hp is not cheap, so you can forget about paying twice the people or the price difference
a 1000hp v8 in not going to be reliable, it will need a rebuild pretty often. reliable engine in a street car is one that can do at least 100000km's without a rebuild. and the veyron motor can do that.
like i have said before, i am not a big fan of the w engines and would never buy one, but it will be very hard to make reliable 1000hp on 8 cylinders
Hah!
http://jalopnik.com/5449046/veyron-o...travel-cheaper
Apparently, the English Bugatti owner was tired of paying $21,000 for a routine service, $38,500 for a set of four tires and $46,000 every fourth tire change to have his wheels x-rayed to check for stress fractures. In comparison, an annual service on a Ferrari Enzo costs just $2,730.
Provide proof that the Veyron's W16 can do that mileage without a rebuild..
Old Aug 30, 2010 | 12:39 AM
  #58
c5blkvette's Avatar
And back to advanced engineering tech... The VW R32 is a nice design as it reduces the cost of multiple cylinder heads and valvetrain components. Only downside I can see is that it would be a taller engine: high center of gravity and fitment issues:
Old Oct 5, 2010 | 08:47 PM
  #59
THErobertH's Avatar
Originally Posted by eseibel67
Unecessarily complex. .
Agreed. Would this be quad cam on each side? Or use different size pushrods? I have no idea how the valve train would work.
Old Oct 6, 2010 | 02:56 AM
  #60
DOHC each bank (for a W engine). You use rockers to get the valve actuation over to the offset cylinders. as said above the R32 engines are tried and tested. they get a 3.2ltr unit into a space that would normally house a 4 pot engine (2.0-2.4ltr).
It would be intrsesting to see what a W12 engine would look like compeard to a LS engine. two R32 (or even R36) engiens would give you 6.4 (7.2) ltrs with 48 valves! think people are pushing about 800bhp out of these engines so it should be pretty eqsy to get over 1000bhp out of a W12. Obviously as discussed before main bearing support is going to be the problem. the maincap are going to have to be special to take the load. Maybe a built in cradle could be used that linked all the mains together and boted to the block aswell..... Cross bolting would also help......
Chris.
